Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter
South East Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 84 votes, 5.00 average. Display Modes
  #16726
Old November 6th, 2019, 08:28
SlowXj SlowXj is offline
You need to look into the blend door. Sounds like it's not closing the outside air out. I'm having this problem with my 99xj.
Old November 6th, 2019, 08:46
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
Re: Weekend is over...what did you get done?
Originally Posted by PacificEd View Post
I flushed two heater cores, one in a 1998 XJ and another in the 1998 ZJ. I then swapped out another radiator that was leaking at the tanks. I'm becoming a pro at this. I'm hoping that the 3rd times a charm.
After doing all that the dumb thing doesn't make any heat inside the Jeep. It blows outside temp to slightly warmer but never gets HOT. I burped the air from the heater core lines. The ZJ runs just under 210* with the 4.0L. Any ideas why it isn't warming up good?
Sounds like a blend door issue maybe?
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old November 6th, 2019, 09:06
thechief86's Avatar
thechief86 thechief86 is offline
Originally Posted by Cottontail View Post
Atta boy Eric. Where did you buy?
Thanks Dirk. New house is in Bethpage, TN, a little north of Gallatin. Definitely rural, but it's pretty out here.
Tomorrow I'll bring my xj home, hopefully with a brand new set of cheap mud tires on it.
How are we posting photos these days, now that photobucket decided to suck for image hosting?
Old November 6th, 2019, 09:39
PacificEd's Avatar
PacificEd PacificEd is offline
Thanks guys. I think you are on the right track. I've done some searching and found a lot of information that points at either a vacuum line issue or more a more likely issue with the blend door motor/cracked plastic gears. I've found what I need to look over so I may be able to get this fixed soon.
Thanks for the help fellas!
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Old November 8th, 2019, 03:50
thechief86's Avatar
YAY! I got my XJ home yesterday! drove it about 70 miles yesterday, and got some new 31's and some steelies put on it.
The jeep needs a lot of work still, but it ultimately drives pretty good. I did get death wobble a time or two driving on the interstate with old, dryrotten tires, but not after I got the new shoes on. I did find a bad front hub, and I will need an adjustable track bar, but this jeep will be simple to make a weekend warrior out of without spending too much money on it.
I think I do want to find an 8.25 and a d30 with 3.55 gears to swap in, to get rid of the CAD and spindly rearend, but I have other fish to fry first.
Old November 8th, 2019, 06:38
bosco01xj's Avatar
bosco01xj bosco01xj is offline
Nice. I'll keep a lookout on Facebook for axles. I see guys selling them all the time so if I see it, I'll send you the link.
Old November 8th, 2019, 06:43
bosco01xj's Avatar
Well... looky what I found:
Louisville KY. It looks like he wants $360 for a D30 and 8.25 out of a 99.
https://www.facebook.com/marketplace...6826485496433/
Old November 8th, 2019, 06:55
thechief86's Avatar
Thanks buddy. I need to sort other issues before I go down that path, but I'll get there. I don't plan to go bigger than these 31's, so the stock junk will suffice for now.
My biggest journey on this jeep will be replacing all the corroded and disintegrating fuse terminals in my fuse box. That is going to be a real job, I'm afraid. Once that is done, I'll be able to DD this thing and replace worn parts as I find them.
Old November 8th, 2019, 17:40
Just as a side note Ed. I believe 99 was the first year of the servo motor controlling the blend door with the cracking gears. If you're before that if put money on a vacuum leak.
Old November 9th, 2019, 22:53
So I have to ask/tell on my own ignorance...
I stretched the front about 1.5 inches (guestimating) in doing so everything was great except the metalcloak coils hitting the iro track bar bracket on compression. Axle was centered with panhards, but then I shifted it about 3/8ths driver to help clear everything. What are your thoughts guys? Leave the small stretch and keep the offset axle, or no stretch and perfect panhard position.
No bump steer/death wobble, or anything.
Old November 10th, 2019, 05:08
thechief86's Avatar
https://lh3.googleusercontent.com/fO...=w1723-h969-no
Old November 10th, 2019, 05:10
thechief86's Avatar
The Track-Bar offset will cause premature wear of the trackbar itself, at the joints, as well as premature tire wear. I'd rather sacrifice the stretch.
Old November 10th, 2019, 06:02
PacificEd's Avatar
Here is the pic. I love the wagon wheels.
Old November 10th, 2019, 06:38
thechief86's Avatar
I can't figure out how to get the IMG code for my images to paste on this site, but here are links to current photos of my 2 door.
https://photos.app.goo.gl/fFCSCszYKzBDDHRg7
https://photos.app.goo.gl/KZPhhmSVBL7kbCVU8
https://photos.app.goo.gl/p38QFXTJ2zz4XAnf9
https://photos.app.goo.gl/8NvNdriRUo7ZN77p8
Old November 10th, 2019, 06:41
thechief86's Avatar
Thanks Ed!
Just trying to show off where I'm at with the project.
I'll do some more work to eliminate the Death Wobble, then take it into town and give it a good bath, and replace the windshield.
Touch up paint for the primered spots, and some electrical repairs, and I should be able to drive it anywhere I wanna go.
Then I will start working on off-road improvements.
Rate This Thread:
What I did this weekend Starscream Modified Tech Discussion 27 January 6th, 2008 21:28
Took the weekend off.... jpbxj79 Colorado Chapter 3 July 24th, 2007 21:15
2nd Annual NAC Mohawk Madness Weekend Sept 3-5th labor day weekend sidriptide North Atlantic Chapter 77 September 19th, 2005 19:48
anybody going anywhere this weekend? MMIXJ Colorado Chapter 5 September 10th, 2004 14:19
