Old February 1st, 2017, 07:17
Racer~X's Avatar
Racer~X Racer~X is offline
Re: Greg Smith Power door locks writeup PRE-1991
Originally Posted by DrewMogz View Post
I hope that someone out there still follows this thread, especially you Greg. I removed the kick panel and exposed all the wiring and I see several different tan and green wires coming from place to place and there's two blue relays attached to the metal housing, so I'm not sure which one's or where I'm supposed to be taking these wires apart at.
I was really hoping someone still had a diagram, schematic or pictures of what I'm supposed to be doing since apparently I'm pretty dumb electrically wise.
--- http://imgur.com/CALAaeB
<blockquote class="imgur-embed-pub" lang="en" data-id="CALAaeB"><a href="//imgur.com/CALAaeB"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
Old February 22nd, 2017, 00:19
ted939 ted939 is offline
I have several questions about this process, going back to Greg's original post in this thread. I'll paste his post here, with my questions in-line with that paste in underlined italics:
The Fix/Repair:
First make sure you are getting around 12 volts of power to your passenger side door switch directly or when you trigger the lock or unlock switch from the driverís side or by the remote. What and where is this remote referred to here?
You can test the voltage with a multi-meter at the wire harness connector in the passenger-side kick panel where the dark green, white and red wires go into the front door. To test the voltage, where at those dark green, white and red wires do I put the 2 prongs from the multi-meter?
Assuming you have a full voltage supply to the passenger side switch, the fix is to install two relays in the passenger-side kick panel on the lock and unlock wires coming from the passenger side switch. Which are these lock and unlock wires?
The relays will increase voltage back up to 12 volts to compensate for the loss caused by the passenger side switch. With the voltage increase provided by the relays, the voltage at the remaining power door locks is increased by approximately 2 volts, enough to power all the locks, even in cold weather. This of course assumes that no wiring problems exist from the splices to the door locks. If you still have a problem at a particular door lock measure the voltage and make sure it is over 9 volts. With my fix it should be closer to 10 and perhaps 9 at the rear hatch. Where do you put multi-meter prongs at each particular door lock and at rear hatch to measure the voltages?
The relays to use are 5 blade, 12 volt, 30 amp minimum rated relays with blades marked 85, 86, 87, 87a and 30. These relays are the same as those used for the keyless remote relays found in the passenger-side kick panel What/which relays are these keyless remote relays in the pass-side kick panel?
so you may find them cheap at the bone yard. You can also find them in automotive electric supply stores. Look in the section that has lighting upgrade supplies. For an easier install it is also best to buy wiring sockets that fit the relays. Here is a link to partsexpress.com an online supplier that has relays and sockets at reasonable prices. I used 2 bosch relays # 330-070 and 2 sockets # 330-075 (although 1 dual socket 330-078 could be used I believe). http://www.partsexpress.com/webpage....oup_ID=31&SO=2
"Here is how I did the wiring: I used the two 12v relays. They have 5 blades: 86 is trigger pwr from the passenger dr switch; 85 is ground; 87 is the new pwr source; 30 is the path to the lock and 87a is to ground (in this application). Is the preceding sentence describing how Jeep already is, or what we're going for?
I cut the Lgreen What does "Lgreen" mean?
and tan wire about 5 inches forward (toward the front of the Jeep) of the wire harness connector that connects the wires to the wires coming out of the passenger frnt dr. In this example I attached the tan unlock wire coming from the passenger frnt door to 86 and 85 to ground Does that mean the tan wire goes to 86 AND 85 AND on to ground - OR tan goes to 86, while we put some other wire from 85 to ground? If the latter, what kind of wire (gauge, material), and to where should we ground it? How to connect the wires to the blades?;
30 is attached to the tan wire going to the door locks Didn't previous sentence instruct to connect tan wire to 86 (as opposed to this sentence saying tan goes to 30)?;
and 87a is to ground I thought I just read that 85 goes to ground, no?.
I used the new 10 gauge pwr line I had previously run to the battery/starter relay post with a 30 amp inline fuse. Whoa! What is this new pwr line previously run? I didn't see any mention of that. How/where is this done?
You can take off pwr from a splice on the red pwr going into the passenger door instead. What does "take off pwr from a splice" mean?
(The same approach is used for the lgreen wire using the other new relay for for the lock circuit.) The key to making this work was 87a to ground. When the lgreen or tan wire are not in pwr mode they provide ground path to ground through the driverís side switch. With my new relays I substituted a new body ground instead What/where/how is this new body ground done?.
As a result I increased voltage and created new better grounds. The locks now all slam open and closed even in very cold weather. Hope this helps."
Back to Ted939 writing now:
I'm stoked that Greg's fix has helped so many people, but I obviously don't speak the language of the relay world - but I wish I did, as my 1988 XJ's locks have been slow/sticking for years. Some of them won't even budge most of the time.
Any chance someone could translate Greg's instruction to a step-by-step that a 4th grader could understand (then, I might get it!)?
As for cleaning and lubricating the actuator, linkages, latch, what are the best substances to use for those? I saw mention of a couple few different things. Is there a consensus on which are best?
Anyone in San Diego area that's done this, and I can come look at what you did? I'll bring food and drink!
Old February 22nd, 2017, 05:22
90xj06's Avatar
90xj06 90xj06 is offline
i have edited in red.
Also i may be able to snap some photos if that will help you.
The Fix/Repair:
First make sure you are getting around 12 volts of power to your passenger side door switch directly or when you trigger the lock or unlock switch from the driver’s side or by the remote. What and where is this remote referred to here? i believe this to be the keyless entry remote
You can test the voltage with a multi-meter at the wire harness connector in the passenger-side kick panel where the dark green, white and red wires go into the front door. To test the voltage, where at those dark green, white and red wires do I put the 2 prongs from the multi-meter? measure them at the passengers door. red is 12v constant white and dark green will normally be grounds unless the drives side door switch or keyless entry remote buttons are pressed. it will flip 12v on white or dark green depending on lock or unlock.
it will be the tan and Light green wires that exit that exit the passengers door wiring loom The relays will increase voltage back up to 12 volts to compensate for the loss caused by the passenger side switch. With the voltage increase provided by the relays, the voltage at the remaining power door locks is increased by approximately 2 volts, enough to power all the locks, even in cold weather. This of course assumes that no wiring problems exist from the splices to the door locks. If you still have a problem at a particular door lock measure the voltage and make sure it is over 9 volts. With my fix it should be closer to 10 and perhaps 9 at the rear hatch. Where do you put multi-meter prongs at each particular door lock and at rear hatch to measure the voltages?honestly i skipped this step if your having issues i would do the relays first
they are taped together should be the only relays over there. so you may find them cheap at the bone yard. You can also find them in automotive electric supply stores. Look in the section that has lighting upgrade supplies. For an easier install it is also best to buy wiring sockets that fit the relays. Here is a link to partsexpress.com an online supplier that has relays and sockets at reasonable prices. I used 2 bosch relays # 330-070 and 2 sockets # 330-075 (although 1 dual socket 330-078 could be used I believe). http://www.partsexpress.com/webpage....oup_ID=31&SO=2
"Here is how I did the wiring: I used the two 12v relays. They have 5 blades: 86 is trigger pwr from the passenger dr switch; 85 is ground; 87 is the new pwr source; 30 is the path to the lock and 87a is to ground (in this application). Is the preceding sentence describing how Jeep already is, or what we're going for?what we are going for
Light Green and tan wire about 5 inches forward (toward the front of the Jeep) of the wire harness connector that connects the wires to the wires coming out of the passenger frnt dr. In this example I attached the tan unlock wire coming from the passenger frnt door to 86 and 85 to ground Does that mean the tan wire goes to 86 AND 85 AND on to ground - OR tan goes to 86, while we put some other wire from 85 to ground? If the latter, what kind of wire (gauge, material), and to where should we ground it? How to connect the wires to the blades?tan goes to 86 then a separate ground wire goes to 85;
30 is attached to the tan wire going to the door locks Didn't previous sentence instruct to connect tan wire to 86 (as opposed to this sentence saying tan goes to 30)?you cut the tan wire inhalf both halves need to be connected to the relay;
and 87a is to ground I thought I just read that 85 goes to ground, no?87A is the ground for the circuit 85 is the control ground for triggering the relay.
I used the new 10 gauge pwr line I had previously run to the battery/starter relay post with a 30 amp inline fuse. Whoa! What is this new pwr line previously run? I didn't see any mention of that. How/where is this done?i used 12gauge wire i went from battery + to a 30A inline fuse and drilled a hole under the HVAC box
You can take off pwr from a splice on the red pwr going into the passenger door instead. What does "take off pwr from a splice" mean?id ignore that part if you run a new wire from the battery
(The same approach is used for the lgreen wire using the other new relay for for the lock circuit.) The key to making this work was 87a to ground. When the lgreen or tan wire are not in pwr mode they provide ground path to ground through the driver’s side switch. With my new relays I substituted a new body ground instead What/where/how is this new body ground done?i just put a sheet metal screw into the body in the kick panel location..
Old February 28th, 2017, 22:19
Modrod Modrod is offline
I did this door lock fix verbatim and it worked great. My Jeep sat for a few years as I was redoing some things and the actuators became stiff and even with the new wiring and relays it was back to not working well. I poked a hole in each of actuator boots and used the provided straw and sprayed some graphite oil in in each of them along with some 3 in 1 oil in each of them. I then lubed all the lock rockers and linkage. Now they work better than ever, they are very quiet now because they are so smooth. I lubed the window cables and the tube they go into at the bottom and now the windows are fast. This is an old post but thought people are still referring to it for help and wanted to add to it. Thanks to the guy who put this fix on here.
Old September 5th, 2017, 22:01
JohnnyAndMerle JohnnyAndMerle is offline
Just wanted to add to the list of "thank you's". I just bought an '88 XJ two days ago. The doors had been removed by the PO, who had owned it for several years. When I picked the Jeep up I threw the doors in the back of my pickup truck, thinking it would be no problem to put them back on. When the time came to attach the wires, I was totally befuddled by seeing all the female wire connectors and a couple of relays under the passenger side kick panel. Needless to say, s*** wasn't working right. After two days of Google searches, poring over wiring diagrams, and perusing various forums, I somehow found this thread. When I started reading about the two relays and cutting wires, it was as if the clouds parted and a ray of sunshine filled my soul with joy! Apparently, the PO had used this solution however many years ago, and neglected to tell me about it. God bless the internet, and God bless Greg Smith.
Old January 9th, 2019, 10:55
Weslope90 Weslope90 is offline
This is a long shot due to the age of the post I found, but how do I get a copy of the diagram for the 1990 and earlier XJ power door lock upgrade?
Old January 9th, 2019, 10:57
I think I just answered my own question.
Old January 9th, 2019, 16:57
cruiser54's Avatar
cruiser54 cruiser54 is offline
Never was one that I know of.
I did 2 or 3 of them. Just read it.
Old January 20th, 2019, 04:34
bcmaxx's Avatar
bcmaxx bcmaxx is offline
Holy hell! This forums alive! All these years later im about to do this
Old January 20th, 2019, 05:53
cruiser54's Avatar
Make a diagram while you're at it.......
Old January 26th, 2019, 07:58
arto_wa arto_wa is offline
Yes that would be really handy to have!
I have the door panels off of my 89 XJ while installing new speakers and am contemplating if I should install the relays now or not?
The windows work but the driver side front is pretty slow. The power door locks definitely need some help since they are really stiff.
Silicone spray in the linkage has helped some.
Old January 27th, 2019, 20:22
cruiser54's Avatar
The mod is done in the passenger side kick panel.
Old February 28th, 2019, 09:44
rynoshark rynoshark is offline
Does anyone have an original pre-1988 full cross-body wiring setup, all ready to go with all the mods/fixes and the door panel switches/surround? I'd really be interested in buying.
Old April 5th, 2019, 22:23
Glacko Glacko is offline
Ok so I did this fix, my door locks are like, super strong now but, my power antenna wont stop working so I had to pull the fuse for it, 1) what could this be resulting from and 2)will this drain my battery as a result? For the pwr wire I did I chained both pwr wires going to the relay from the red wire going into the passenger door like he stated.
Old April 8th, 2019, 12:06
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Long as you have the fuse pulled, it won't drain the battery. Have the same problem with my power antenna, been meaning for years to fix it (mine's stuck in the "up" position)
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Thank you Greg Smith... jmeti000 OEM Tech Discussion 3 November 23rd, 2014 14:53
Greg Smith Power Door lock writeup XJEEPER Modified Tech Discussion 8 January 12th, 2013 17:16
Power Door Locks - FIX Rear Hatch & Driver Door 5bucks OEM Tech Discussion 3 October 14th, 2010 22:58
Greg Smith power door lock questions??? xjtrailrider OEM Tech Discussion 15 December 19th, 2009 18:52
Greg Smith kellen OEM Tech Discussion 3 September 13th, 2004 05:17
