Old November 10th, 2019, 18:22
RCP Phx RCP Phx is offline
Re: going crazy... rattle noise
Originally Posted by lazyxj View Post
Try setting the rear axle on jack stands, remove the wheels and rear driveshaft and then spin the pinion shaft with your hand, feeling for roughness or a loose yoke.
A shop is going to charge you $100+ an hour to search for this noise, searching more deeply yourself could save you a bundle and it's a lot more satisfying finding the problem yourself.
Wise words spoken there!
Old November 11th, 2019, 20:28
blu3fan's Avatar
blu3fan blu3fan is offline
Took it to a diff shop today-
They agree its the pinion bearing and for $550 including parts and labor to redo all the inner bearings its not a ripoff.
just gonna pay them and check this off the list.
Old November 11th, 2019, 20:34
blu3fan's Avatar
Done that about 5 weeks ago. and again last weekend.
Nothing is loose.
Nothing makes noise.
Noise only happens at 5-10 mph on ground. nothing more nothing less.
I am not gonna spin the driveshaft quick enough to cause it sadly.
I am almost 100% sure its a stuck/frozen roller in the top of the yoke. due to worn down bearings the pressure is not on it until driving force is applied.
or at least that's what it sounds like.
gonna throw the $550 at the shop and hope to science it fixes this 3 month nightmare of finding this..
Old November 12th, 2019, 09:25
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
i have a click type sound that threw me for a loop this summer. turns out it was the spider gears ( but this was my front diff). this was audible by pulling the diff cover and spinning the axle shaft. i only heard it when slowing down, usually a short ways before stops.
any chance you can wire your phone up near the axle ?
Old November 12th, 2019, 10:55
blu3fan's Avatar
Diff shop just called.
Pinion bearing is shot. Gears are not terrible but have some sharp edges on teeth. Replacing gear and pinion while in there.
Old November 12th, 2019, 12:36
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
This would be the time to drop in a locker or, my preference, a Truetrac.
I have used Truetracs for a couple decades and love how they are invisible and work all the time. My 2001 XJ's Truetrac has about 150,000 miles on it and still works like new.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old November 12th, 2019, 16:52
blu3fan's Avatar
If I had the money id totally do it.
The shop let me know my driveshaft is binding a little bit due to the lift and I suspect that is why the pinion bearing failed.
They said they do a custom driveshaft and slip yoke eliminator for 900 out the door. I dont know if they know I have a 242.. im going to inquire more about that around tax time.
Old November 12th, 2019, 16:59
blu3fan's Avatar
but honestly probly do a hack and tap and have them make me a driveshaft.
This shop actually seems reliable not not ripoff prices.
Old November 13th, 2019, 16:32
blu3fan's Avatar
so.
Just picked her up from the shop.
about half of the noise is gone.
so I think I have had two issues.
The bad noise appears gone- and now I just have something residual to figure out. still a rattle. but nowhere near as bad.
Old November 13th, 2019, 20:06
is it the same sound?
im glad you figured out your pinion issue. do you have a slip yoke that could be rattling around on the tc ouput? those can make weird noises
Old November 13th, 2019, 20:10
if any of your remaining sounds are in the fashion of your described first post, I still would pull driveshafts as Anak suggested. It will narrow down a lot of options quickly if something changes.
Old November 16th, 2019, 06:29
blu3fan's Avatar
so the remaining noise- I have narrowed down to something in the xfer case or transmission.
Im over trying to diagnose it- just gonna drive til it breaks or gets worse to the point that I can figure it out.
Old January 8th, 2020, 16:53
blu3fan's Avatar
so update.
After Xfer case rebuild.
Rear Diff Full bearing change.
the noise got worse.
Its in the drivers side brake. Gonna rip it all apart this weekend.-
But hey.... at least I fixed stuff that wasnt broken....
Old January 8th, 2020, 16:54
blu3fan's Avatar
I suspect the drum is out of round. Somehow.... after an alignment... odd....
who knows what they did...
Old January 19th, 2020, 17:18
blu3fan's Avatar
soo.
pulled the drum off.
The rectangular spring on the upper drum was missing......
idk if it broke and fell of. or the shop that aligned it was screwing with me.
new spring arrives Tuesday.
crazy tc noise jake66 OEM Tech Discussion 1 December 12th, 2010 13:58
another front end rattle/grind noise question whatevah OEM Tech Discussion 5 June 15th, 2008 16:31
Noise: Whoosh, Rattle, Tornado 5bucks OEM Tech Discussion 0 July 7th, 2006 12:11
Rattle noise at engine shut off/96xj/4.0/AW4/242 WVXJ OEM Tech Discussion 5 June 29th, 2005 12:59
engine noise - rattle at high rpms fordtech OEM Tech Discussion 0 September 17th, 2004 07:00
