Old October 28th, 2019, 19:57
devildog0's Avatar
devildog0 devildog0 is offline
Re: Transfer Case drain and fill Fears coming true?
Originally Posted by Tim_MN View Post
A rattle at the 4x4 shifter is typically worn out bushings in the shift mechanism.
You seem to have the Cherokee manual transmission confused with the transfer case. Both the NP231 and the NP242 use ATF, not gear oil or 10W-30. Some people claim that New Process 231 and 242 transfer cases can safely use synthetic 5w30 engine oil, but there is no reason to use other than what is recommended, ATF. My 98 has +284,000 miles and the ATF filled transfer case shifts smoothly and makes no noises.
Novak claims on their site that many folks are running 30 weight oils in the 231 and 242 woth no ill effect. Who knows. ATF is cheap and works fine.
Sent from my SM-G892A using Tapatalk
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old October 29th, 2019, 16:24
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Thought there were clutches? May be that's the 249 I'm thinking about.
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old October 29th, 2019, 21:48
lawsoncl lawsoncl is offline
I'd be hesitate to run 10W-30, since the viscosity is twice as thick as Dex-III at 100*F.
Old October 30th, 2019, 06:41
10-30 was only suggested to be run in HIGH heat,HIGH load situations, where ATF was foaming and misting out the vent.
It was not to be used in NORMAL situations.
Wayne
Member#17
Old November 12th, 2019, 10:03
cmahaff cmahaff is offline
Hello 👋
I've been out of service for a few weeks
I am confident in the fluid that I used and don't think that is causing the sound.
I wonder if my Google drive link worked and anyone can hear the sound. It's most prominent starting at about nine seconds.
Old November 12th, 2019, 18:21
blu3fan's Avatar
blu3fan blu3fan is offline
having just rebuild my xfer case due to a rear pinion leak. I can say. you can change the chain without pulling the case.
in fact I recommend you do it this way.
if you want to do the bearings too. pull it.
its a days work.
You need a slide hammer and the special pliers.
Old November 13th, 2019, 09:39
I guess if the chain was loose enough it could be making a metal on metal sound due to engine vibration. I'm hesitant to blame the chain now, because it hear it when the vehicle is not moving.
The chain shouldn't be moving in that instance right?
Old November 13th, 2019, 10:24
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
A rattle under the floor console is typically worn out bushings in the 4x4 shift mechanism. The chain would only make noise if it was moving.
Applying some light downward pressure on the shift handle, or pulling up very slightly usually stops the rattle, and confirms that the shifter mechanism is the root cause. Naturally you need to also check that the exhaust is not making contact with the crossmember, or the unibody.
Originally Posted by bimmerjeeper
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old November 13th, 2019, 12:44
Applying some light downward pressure on the shift handle, or pulling up very slightly usually stops the rattle, and confirms that the shifter mechanism is the root cause. Naturally you need to also check that the exhaust is not making contact with the crossmember of the unibody.
To me, the noise represents more of a light grinding than a rattle. I will check the shift handle and see if any change in its position alters the sound
I also want to put it in 4wheel drive and listen for the sound
I intend on fixing the exhaust resting on the cross member soon. I know that is making a noise. But I think it's different. In the mean time I want to put a wood door stop between the two, just to rule it out
Old November 13th, 2019, 21:17
md21722 md21722 is offline
Nothing inside the transfer case moves when the vehicle is stationary.
In 2wd drive mode, the chain turns with the front output yoke turns, so typically anytime the vehicle is moving & the front driveshaft installed. In this case its 'freewheeling' and not under load.
In 4wd move, the chain is under load as it's being 'driven' by the main shaft. The transfer case forces the front output yoke to turn.
All 'selection' and 'operation mode' is done by way of forks on the main output shaft which selectively engage or disengage the chain/front output.
The way the transfer case is built, the front output is 'direct drive' via the chain to 'main shaft'. So by way of mode selection, the front output/chain are either freewheeling or driven and this occurs by way of the forks on the main shaft side of the case.
This may make more sense if you ever split the case open.
transfer case drain and fill plugs stuck frozen iluv83vettes OEM Tech Discussion 22 January 22nd, 2015 20:33
Socket Size Transfer Case Fill/Drain Bolts ihscoutlover OEM Tech Discussion 1 May 28th, 2013 20:10
t-case drain/fill plugs leak gw204 OEM Tech Discussion 1 September 2nd, 2009 08:43
Transfer Case Drain/Fill only 1.5 qts?? Sleepydog OEM Tech Discussion 14 September 15th, 2008 21:56
92 4.0 auto tranny, xfer case fill&drain plugs 30mm? Heinz OEM Tech Discussion 1 June 6th, 2004 13:35
