Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Grand Cherokee > ZJ and WJ Grand Cherokees (1993 - 2004)
ZJ and WJ Grand Cherokees (1993 - 2004) Technical forum for the classic ZJ and WJ Grand Cherokees.
Old October 18th, 2019, 19:56
PacificEd's Avatar
PacificEd PacificEd is offline
ZJ radiator woes
My 1998 4.0L Grand is having radiator issues again.
I have swapped out two OíReillyís units in the last few years. And itís leaking again.....ugh. Both have leaks where the tank meets the core.
So what works for you guys? I see no copper/brass units. I see the crappy plastic tank/aluminum core junk. I found a Griffin all aluminum but they are really expensive.
Any other options out there?
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Old October 18th, 2019, 21:24
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
Re: ZJ radiator woes
I ran a tyc one in my XJ for years. Just got it off rock auto.
You could look for a mopar they will still be aluminum and plastic but better built.
All Aluminum ones are just crazy expensive and I just have that much faith in them.
88 MJ truggy, 4.0HOybrid AX15, NP242 **Being built**
Mods: D44 w/ 4.30's, ARB front and Auburn rear, 33's
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Old October 18th, 2019, 21:31
jeep ride's Avatar
jeep ride jeep ride is offline
I used one from Napa about 8 years ago no leaks so far they have changed brands now though.
Old October 19th, 2019, 06:56
PacificEd's Avatar
The Mopar unit is $240 from RockAuto. A CSF or Spectra (I think this is the same as the O’Reiily’s) is about $81. I just like to swap this one last time. If the Mopar one is that much better, I’d be interested in trying it. But I’m scared it won’t be much better and cost more.
Old October 22nd, 2019, 19:03
PacificEd's Avatar
O’Reilly’s says it’s under warranty so it looks like I’ll be installing another Murray radiator. I’d like something better but what can you do? Most people say they are all the same anyways.
Radiator Woes!! Nolaws OEM Tech Discussion 22 December 2nd, 2012 12:32
radiator woes.... BJL913 Colorado Chapter 8 October 16th, 2011 23:20
Radiator Spout where hose connects to radiator overflow bottle.. gregmondro OEM Tech Discussion 10 August 16th, 2009 08:59
tranny cooler/radiator quick disconnect woes ChevelleSSLS6 OEM Tech Discussion 11 June 25th, 2009 07:34
