Old September 21st, 2019, 04:02
rain164845 rain164845 is offline
Re: Blowing smoke from exhaust
Originally Posted by Down under View Post
Are you getting a lot of condensation at the exhaust
I did notice condensation, yes.
Old September 21st, 2019, 13:15
lawsoncl lawsoncl is offline
Some condensation while warming up or cold out is normal. A lot after it warms up on a warm dry day is not, and could indicate a head gasket issue. I suspect your current problem is a fuel problem.
Old September 21st, 2019, 23:47
Down under Down under is offline
Pretty sure when an injector has pooped itself, they stay in an open position (constant fuel feed).
Thus emitting access condensation and a cloud of smoke (un-burnt fuel), commonly mistaken for blown head gasket.
But with your previous posts, I would not fit new injectors just yet until you replace the fuel filter and flush etc.
Inspect the sump oil for water contamination. (Blown head gaskit)
Could be all of the above.
Old September 28th, 2019, 14:57
Great news, the Jeep is up and running!!!!
Replaced fuel tank, pump, filter, iac. Took off valve cover and degunked the baffles and snorkels. Also did the front shocks, rotors and pads once it was drivable.
If imgur starts working again, I'll load videos. I think the billowing smoke was oil getting sucked into the intake manifold due to the baffles in the valve cover being gunked up. I think that it just so happened that the fuel pump died at the same time.
Old September 28th, 2019, 15:31
Good stuff! A friend of mine who i had just rang was about 2 minutes from getting a 2nd hand motor put in, because of a smoke cloud coming out of the exhaust on a newish car he bought.
And this problem started not long after he did an oil change and using an engine oil flush treatment.
Thought he had stuffed the motor.
So I told him to disconnect the breather line to the intake, and take it for a good blat.
Sure enough the smoke slowly faded.
Went to his house, ripped off the cover..... Sure enough his looked like yours did.
The engine flush loosened all the crap on the cover and around the baffle, and was getting sucked up through the breather.
Saved him $5 grand!
Cleaned it up, put a $15 catch can in the line. A few cans of cleaner, and new plugs.
Presto!
Good chance you will have some soot and gunk in your manifolds and around the valves and in the exhaust pipe.
Give it 100kms, then pop your plugs out, dump a full can of cleaner down the throttle, let it sit for a minute, crank to move valves, as some will be closed and not get a soak etc , then give it another full can . Then get a friend to crank it for you whilst you use an air pistol down the throttle and cover the gap with a rag to stop the air getting out past it. Then do the same into the pots, give each pot a spray/soak, crank , blast into pot, don't put the tip of the air pistol to far in!
Refit your plugs , run till warm, then use the cleaner down the throttle in the standard way,.
Go for another blat to spit it all out of your exhaust system.
Old September 28th, 2019, 15:36
Disconnect the fuel pump fuse, and wear some eye protection when doing the pots!
Old September 28th, 2019, 18:42
Videos.
http://imgur.com/gallery/bN8VAsc
black/white smoke, blowing oil? paroxysym OEM Tech Discussion 3 May 26th, 2009 08:37
Blowing black smoke... HELP! smASHLEY OEM Tech Discussion 3 March 18th, 2009 15:32
Blowing Smoke up your...... My_Little_Pony OEM Tech Discussion 22 September 3rd, 2004 12:14
Blowing Black Smoke ipower OEM Tech Discussion 3 January 5th, 2004 16:47
