Old November 17th, 2019, 14:17
lawsoncl lawsoncl is offline
Re: Low idle while coming to complete stop?
Originally Posted by MickeyS View Post
Well my vacuum at the manifold is fluctuating pretty good. I don't have any reason to think the gauge is broken but I borrowed it from a friend who had never used it.
https://youtu.be/gnb12BEDUfI
Low and erratic, web search seems to diagnose valve springs. I will try to get ahold of another gauge to do a dummy check.
The bouncing needle is perfectly normal. Some gauges have a small valve to dampen the oscillations of the needle. The amount of vacuum at idle doesn't seem that low to me.
Old November 17th, 2019, 14:20
MickeyS MickeyS is offline
Fuel pressure is a perfect 49
another view of a plug with what looks like oil on the threads. it does read as oil on paper towel. I don't seem to be visibly burning any or missing much oil from the crankcase, not sure if this is from a previous leaking valve cover or what.
thanks. if so, that's great news. everything I'm reading on youtube university and academy of google says this is abnormal, to not have a solid needle.
Old November 17th, 2019, 15:57
https://www.youtube.com/watch?v=vh3Z-F6KGkI
I watched this video and the wobbling needle on the gauge later still looks a lot better than mine.
Old November 17th, 2019, 16:48
In the video, he's using a gauge meant for checking engine vacuum that has some dampening. The dampening is typically added by a restricted line, a weighted needle, or oil in the gauge. You're using the gauge on a mity vac hand pump which has no dampening so you're going to see the pulsing more pronounced at idle as each cylinder pulls on the intake stroke. If the needle is consistently dropping a lot once per rev rather than bouncing around at 6x the revs, then I'd suspect maybe a problem with one cylinder and then do a compression test which would be much more revealing. Even slowed down to 1/4-speed, I don't see more the needle wagging more than a few psi.
The gauge set I use to sync motorcycle carbs measures each cylinder separately and you can really see the oscillations on each piston stroke. This gauge set has valves on the vacuum line you choke down to get a reading steady enough to balance the carbs.
Old November 17th, 2019, 18:36
cruiser54's Avatar
cruiser54 cruiser54 is offline
Okay. Spray carb cleaner around the intake manifold and see if there's a vacuum leak around #6.
Old November 17th, 2019, 20:23
thanks for taking me to school. I'm going to get a stand alone vacuum gauge from HF to do a dummy test, then get a buddy to help me with the compression test soon. Will also spray around cylinders at manifold (again) as mentioned above, but I had done this a while back.
Old December 3rd, 2019, 18:15
Lawson was totally right. Threw a HF vacuum gauge on the manifold and pull a solid 18 in hg at hot idle with the gauge only instrument. I passed smog today which is good news, if I didn't pass I was going to stop throwing time and money at the issue but the jeep passed with colors, so with perfectly strong vacuum and clean emissions I can start doing more work to get to the bottom of this.
Rpms dive when coming to a stop 4x4JeePmaNthINg OEM Tech Discussion 19 August 16th, 2017 13:01
AW4 stays in 4th when coming to a stop?? Help! pancake OEM Tech Discussion 14 September 7th, 2013 05:21
opel gt runs but dies when coming to a stop blondejoncherokee Tow Rigs and Trailers 13 December 24th, 2009 19:59
Renix idle goes up and down at stop overflow OEM Tech Discussion 16 September 10th, 2009 18:28
Idle drops when I come to a stop Adam96 OEM Tech Discussion 11 March 11th, 2008 14:38
