Old September 24th, 2019, 08:47
old_man's Avatar
old_man old_man is offline
Re: Low idle while coming to complete stop?
Originally Posted by MickeyS View Post
that's almost exactly my attack plan once the weather cools down here. get that damn manifold off swap the mounts and super deep clean the fuel/intake system. I will order a can of that bk44. looks like good stuff the injectors are 180k miles old, but I have run chevron and seafood through it before.
That is your problem... they are not made for seafood, they are made for gas.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old September 26th, 2019, 15:13
MickeyS MickeyS is offline
Originally Posted by old_man View Post
If it is an automatic transmission, the clutch in the torque converter could be staying locked.
How would I figure out if this is happening? I'm a bit dense and don't know much about the transmission. It happens only when coming to a dead stop and then idles up to 740ish in D, and nicely in park 750-800.
I confirmed the maf vacuum elbow was good today and spent a good ten minutes spraying carb cleaner all around the throttle body/injector area and whatever other vacuum lines I could see in the engine bay, and found no leaks whatsoever.
Old September 28th, 2019, 14:23
lawsoncl lawsoncl is offline
A quick check of the t/c unlock would be to drive along steady at highway speeds, and lightly hit the brake with your left foot. You should see the converter unlock and the rpm jump up a bit. Pretty rare to have it not unlocking though, and the usual problem is that it's not locking in the higher gears due to a bad solenoid or bad switch on the brake pedal, or sometimes a bad TPS.
Old September 28th, 2019, 22:33
I understand now how it should work. Just took it for a jaunt on the freeway and the converter unlocked properly. I still have a suspicion this is a fuel/injector/wiring/voltage issue. at night with lights on, cigarette accessories going, voltage can dip to 13.4-13.5 where the rpms can go as low as 650.
Old September 29th, 2019, 06:38
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
I am still wondering if you installed a Cheap crappy Chinese IAC or a genuine Jeep IAC ?
...... voltage can dip to 13.4-13.5 where the rpms can go as low as 650.
That is normal. The alternator typically does not achieve full voltage until about 1500 rpm.
Originally Posted by bimmerjeeper
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old September 29th, 2019, 07:35
no genuine iac now
Old September 29th, 2019, 12:06
techno1154's Avatar
techno1154 techno1154 is offline
no genuine iac now
There are plenty Chevy's that uses the same IAC. That would be a good place to look.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old October 29th, 2019, 11:57
Replaced injector o rings, super deep cleaned throttled body and IAC, OEM IAC and NEW TPS... no change. ran bk22 through. One time idled super low coming to a stop, into the 500s, wouldn't recover until I hit the gas. since then, idle at stop drops to 690 and then recovers. then vacillates between 720-750.
Assuming the issue is with the transmission or the engine at this point and will be doing compression this weekend.
Old October 29th, 2019, 15:15
Down under Down under is offline
Sounds silly, but I had same once.
Ended up being loose battery terminal!
Ran fine under load!
Died in the bum at idol.
Clean and see what happens.
Old October 29th, 2019, 15:49
thanks. I wish it was that simple, but I've replaced the battery and terminals this year.
Old November 17th, 2019, 12:28
Well my vacuum at the manifold is fluctuating pretty good. I don't have any reason to think the gauge is broken but I borrowed it from a friend who had never used it.
https://youtu.be/gnb12BEDUfI
Low and erratic, web search seems to diagnose valve springs. I will try to get ahold of another gauge to do a dummy check.
hottest (#6) plug looks like/there is a bit of oil on the first threads. these have about 4k miles on them.
https://youtu.be/K5qyzRsDhlc
Old November 17th, 2019, 12:37
Fuel pressure is a perfect 49
another view of a plug with what looks like oil on the threads. it does read as oil on paper towel. I don't seem to be visibly burning any or missing much oil from the crankcase, not sure if this is from a previous leaking valve cover or what.
Old November 17th, 2019, 13:23
In edition to the rapid fluctuation on the vacuum needle I'm noticing a good amount of exhaust pulsation and some spray out of the tailpipe but no smoke.
Old November 17th, 2019, 14:07
cruiser54's Avatar
cruiser54 cruiser54 is offline
I wonder if #6 injector isn't opening.
Old November 17th, 2019, 14:16
they all kinda look like that. 6 just looks a bit hotter.
Rpms dive when coming to a stop 4x4JeePmaNthINg OEM Tech Discussion 19 August 16th, 2017 13:01
AW4 stays in 4th when coming to a stop?? Help! pancake OEM Tech Discussion 14 September 7th, 2013 05:21
opel gt runs but dies when coming to a stop blondejoncherokee Tow Rigs and Trailers 13 December 24th, 2009 19:59
Renix idle goes up and down at stop overflow OEM Tech Discussion 16 September 10th, 2009 18:28
Idle drops when I come to a stop Adam96 OEM Tech Discussion 11 March 11th, 2008 14:38
