Old November 21st, 2018, 20:36
XJ99JEEP XJ99JEEP is offline
Sudden drop in fuel economy
I just had a sudden drop in my fuel economy that is pretty noticeable. I donít see any leaks in any fuel lines or anything. Is there a chance that my O2 sensors finally took a crap or that my map sensor is bad. Any opinions that could lead to a resolve?
Old November 21st, 2018, 22:11
lawsoncl lawsoncl is offline
Re: Sudden drop in fuel economy
Possibly. Is the engine fully warming up? I'm thinking stuck thermostat which should be obvious on the dash or a bad coolant temp sensor which can be tested with a multimeter.
Old November 22nd, 2018, 06:29
Yeah the engine is warming up to normal temperatures just fine. Ill check the thermostat and see if thatís the problem.
Old November 22nd, 2018, 06:30
Oops, I’ll check the coolant temp sensor
Old November 22nd, 2018, 08:56
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
A sudden drop of 30-40% in gas mpg's should make one suspect the O2 sensor circuit: fuses, wires, wire plugs, sensor faults.
Checking the thermostat and coolant temp sensor is also a good idea.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old November 22nd, 2018, 11:17
I would suspect a 99 XJ would throw a code for a bad O2 sensor, but possibly not. If memory serves, the CTS on a 99 is the one in the thermostat housing. Resistance should be pretty high when cold, 5-10kohms. Once warmed up, it should be fairly low, around 100-300 ohms or so. When they go bad they often just open up and show really high resistance or open circuit and don't change.
Old November 22nd, 2018, 11:20
How-to reference for checking the CTS
https://www.autozone.com/repairinfo/...00c152800926a7
Old November 23rd, 2018, 19:13
crazymaci's Avatar
crazymaci crazymaci is offline
check for vacuum leaks,particularly on the intake side, i had a little rubber cap crack out and it dropped to 5mpg
Old November 23rd, 2018, 21:08
BALTANAKT BALTANAKT is offline
Take a look at the coolant temp sensor, O2 sensor.
Old November 24th, 2018, 10:52
JeepNoob JeepNoob is offline
I'd be leaning more towards this. Any fault with the ECT or O2 sensor is likely to result in a check engine light with a corresponding code.
Old November 24th, 2018, 17:36
Tim_MN's Avatar
In fact, not so much. Typically they will get weak and do not throw a code until they are well and truly failed.
The O2 sensor is the most logical and most likely suspect. The Coolant Temperature Sensor is the next most likely suspect. Besides, testing them is simple.
Old November 25th, 2018, 17:03
devildog0's Avatar
devildog0 devildog0 is offline
Which sensor feeds the computer data for fueling? The one in the thermostat housing or the one on the driver's side of the head?
I've been battling bad fuel economy and have gotten my numbers up to 16 mpg from 12 mpg. I'd like to squeeze out a little more and my coolant gauge has been a little flaky which is fixed by messing with the sensor towards the rear of the head. It feels like the insulator where the plug hooks to the sensor is rotating back and forth a little bit.
This is on a 95 4.0
Sent from my SM-G892A using Tapatalk
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
99 XJ Sudden temp rise and sudden drop shortly after jjnavarro OEM Tech Discussion 28 August 12th, 2010 11:59
Sudden Drop in gas Milage vajeeper OEM Tech Discussion 5 June 11th, 2009 22:17
Sudden drop in MPG sjx40250 OEM Tech Discussion 6 March 19th, 2007 07:32
sudden drop in fuel economy? Kejtar OEM Tech Discussion 25 April 13th, 2006 16:52
Sudden gas mileage drop Land Yacht OEM Tech Discussion 3 August 20th, 2004 10:54
