Old November 17th, 2018, 09:31
Black1990jeep Black1990jeep is offline
ECU Breakout Test Unit?
For the Renix injected motors like my 1990 XJ has, does someone have a list of pin outs, and values for ohms or voltage for all the sensors?
On my old VW injected Van someone made a breakout box with digital meter that is spliced into the ecu harness for real time as you drive monitoring of the ecu sensors, O2 sensor, ecu voltage, injector pulse, temp. sensors, etc... I made a break out connector for an old injected Porsche, DJetronic system, and simply connect my volt ohm meter to it for testing while in my driveway.
I would like a simular diagnostic thing for my Jeep XJ. where is a good
location to get the sensor data?
Thanks in advance, I will keep you posted of results once I get this figured out. Maybe someone has done this before?
Old November 17th, 2018, 10:56
lawsoncl lawsoncl is offline
Re: ECU Breakout Test Unit?
Have you seen the Renix Engine Monitor?
https://www.youtube.com/watch?v=OFOATa6HGx4
https://nickintimedesign.com/
Old November 18th, 2018, 00:13
uglyrenixxj uglyrenixxj is offline
If youre anywhere near 92563, we could link up and see qhat your jeep is doin with my mt2500.
Lemme know.
Old November 18th, 2018, 06:42
cruiser54's Avatar
cruiser54 cruiser54 is offline
Originally Posted by lawsoncl View Post
This^^^^
Old November 19th, 2018, 08:19
Saudade's Avatar
Saudade Saudade is offline
Your Jeep already has a diagnostic port. Just get a manual for the pin outs.
1988 Laredo 2wd Auto, AKA "Grey Ghost", 203K
Old November 19th, 2018, 09:42
There's not much in the way of analog data on that connector though. A couple of relay outputs, but nothing like the O2 sensor, TPS, etc that he's interested in.
Old November 19th, 2018, 10:06
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
But those can be easily and more accurately read by the nickintime scanner. Why guess with a volt meter when the ecu will tell you what it's seeing?
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old November 19th, 2018, 11:14
Saudade's Avatar
1. They're on Backorder
2. It at least $140
3. I can read a meter.
4. I have an FSM
Not saying it a "bad thing". just suggesting other options.
Old November 19th, 2018, 17:06
2. It at least $140
4. I have an FSM
Yup, most of the individual sensors can be backprobed easy enough. The Renix isn't that hard to troubleshoot with a meter and a little bit of know-how.
Old November 19th, 2018, 21:03
Coffee Drinker
But backprobing the sensor, won't tell you if it's losing half the signal at the C100 connector. I find it best to just ask the PCM what it's seeing.
WTB fuel sending unit 'lock' (holds sending unit to tank) ASAP JrTxJ NAC Classifieds 13 June 19th, 2009 13:44
Crash test dummy - passed my test! Jeep did not. rpraterxj SoCal Chapter 92 May 29th, 2009 03:25
Oil Pressure Sending Unit leaks out back of unit? mramr1974 OEM Tech Discussion 3 March 25th, 2008 03:44
Anybody ever seen a breakout box for the 32way PCM connector? McQue OEM Tech Discussion 5 November 12th, 2007 19:55
89 AC / Heater Control Unit Will This Unit Work ? JeepBoy89 OEM Tech Discussion 3 February 19th, 2006 10:55
