Old April 30th, 2019, 17:55
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: Renix hard to find parts sources thread
I need a part number, source for the AC Delete Idler Pulley/bearing assy. Not the plate, just the bearing or bearing Pulley assy.
Thanks!!!
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old May 1st, 2019, 10:14
Hypoid's Avatar
Hypoid Hypoid is offline
3420 1869 AR BOLT
3300 2201 AR BUSHING
5300 2903 AR PULLEY, Idler
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old May 1st, 2019, 11:50
Hypoid's Avatar
Originally Posted by Hypoid View Post
3420 1869 AR BOLT
This is actually a fairly common part, used for several years. It is available at the local auto parts.
Old May 2nd, 2019, 04:35
Ecomike's Avatar
NAXJA# 2091
Many thanks, but I searched those on Google, something I pretty darn good at, and I did other searches, and got nada zip. Any other ideas? Sellers that would know those numbers, or the OEM Chrysler number? I can usually find aftermarket stuff with the OEM part number on searches.
Is AR an abbreviation??? For what? I was able to find the HO part number, but is somehow different.
3420 1869 AR BOLT
THANKS!!!
Old May 2nd, 2019, 07:17
cruiser54's Avatar
cruiser54 cruiser54 is offline
https://www.google.com/search?q=3420...hrome&ie=UTF-8
https://www.amazon.com/Mopar-Idler-B.../dp/B007NQH0MK
https://www.amazon.com/Crown-Automot.../dp/B00BYNO9W2
Old May 2nd, 2019, 11:05
Hypoid's Avatar
I went to the local auto parts for mine, it came with the shoulder bolt and washer.
Old May 2nd, 2019, 21:10
cruiser54's Avatar
THANKS!!!
Mike, I think you posted in the wrong thread. This one is for hard to find parts........
1500 page hard to find parts quide Ecomike OEM Tech Discussion 8 February 5th, 2019 19:04
Hard to find OEM parts brademerick OEM Tech Discussion 10 August 5th, 2010 15:14
Why are Cherokee parts so hard to find? Doboy71 OEM Tech Discussion 29 February 3rd, 2009 19:05
New Source for Hard-to-Find Parts Sand-Dog OEM Tech Discussion 2 March 24th, 2006 09:14
