Old December 16th, 2016, 21:47
outlander's Avatar
outlander outlander is offline
Re: Renix scanner port data question.
Got mine today instead of monday....guess the mail man felt ambitious...first time for everything
Looks like a well made product!
Old December 22nd, 2016, 21:30
outlander's Avatar
One question i have about this monitor is why it doesnt monitor map voltage?
Old December 22nd, 2016, 21:55
NickInTimeFilms's Avatar
NickInTimeFilms NickInTimeFilms is offline
I don't get email updates for this forum even though I'm subscribed to this thread which is weird. I could add a conversion for MAP sensor voltage if you wanted but it all comes from the same reading.
Old December 25th, 2016, 01:15
outlander's Avatar
Hey nick you might want to go to the user control panel at the top left of thd page and edit your subscription options and/or verify you have the correct address there.
Old December 29th, 2016, 17:40
Well, figured I'd update you guys in here. Next sale goes live New Years Day, 1/1/17 at 12:30AM EST, 16 kits. Got a video if you like those and an ebay link but it won't work until the date above. If this link still doesn't work by then, just search up "Renix Engine Monitor" on ebay after the above date and it should come right up. My account says I'm subscribed but I have a feeling it still won't notify me so I'll try to check back every now and then.
https://www.youtube.com/watch?v=BzR0mN6xJKg
http://www.ebay.com/itm/Renix-Engine...-/262783850744
Old December 30th, 2016, 09:33
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
One think I noted this week with my Snap on MT-2500 is it does not give any CPS data all
Be so cool if yours gave a non running CPS voltage output at the ECU output reading, but I do not know if the RENIX ECU was ever able to that even with the AMC Jeep Renix scanners? Or perhaps read a signal to the ICM-HV coil from the ECU at least to see if the ECU is trying to send a spark to the spark plugs on a no start condition?
We have to use an AC setting on a volt meter and back probe the CPS.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old December 30th, 2016, 13:26
cruiser54's Avatar
cruiser54 cruiser54 is offline
Factory tester never showed CPS info.
Old December 30th, 2016, 13:56
Ecomike's Avatar
NAXJA# 2091
I guess we can use cranking injector open time data from the MT-2500 or other scanners to imply an operating CPS?
I think I will pull the primary spark plug wire and ground it and try my MT-2500 out while cranking to see what data we do get???? Might get some hints, like cranking RPM? Which has a minimum per 5-90 for the ECU to start the engine. Also an actual ms reading (or changing one, or no ms reading-thus no CPS signal) on injector open time might be an indication the ECU has a CPS signal?? Surrogate data indicator?
Never thought of that before, then again my MT-2500 is new to me, barely used 2 since I got it 3 months ago.
Did the AMC-Renix scanner produce any cranking data???
Old December 30th, 2016, 15:14
cruiser54's Avatar
Let me know what you find.
Old December 30th, 2016, 15:31
90xj06's Avatar
90xj06 90xj06 is offline
are you referring to the crank sensor? or the cam sensor?
if the crank sensor is bad it will not show any engine rpms during cranking. and i also think it does not show injector pulse duration too.
there is not a whole lot of information dumped out the renix ecu.
it actually looks dulled down from what its actually capable of.
Old December 30th, 2016, 15:32
cruiser54's Avatar
There is no cam sensor on Renix.........
Old December 30th, 2016, 15:53
Ecomike's Avatar
NAXJA# 2091
Bingo, yes the Crank sensor, so that would answer it, not RPM reading if the CPS is not being read by the ECU, cool, awesome even!!!!
Old December 30th, 2016, 15:55
Ecomike's Avatar
NAXJA# 2091
What ?????
There is a second sensor in the distributor right?
That is in essence a Cam sensor right?
When it goes bad, the Renix ECU takes forever to start firing as it needs that sensor to decide if the CPS signal is the exhaust or compression stroke on cyl #1.
Old December 30th, 2016, 15:57
cruiser54's Avatar
Originally Posted by Ecomike View Post
What ?????
Nope. Has nothing to do with cam sensing.
Not true. Disconnect it and you won't even notice a thing different.
Old December 30th, 2016, 16:17
Jeep Driver Jeep Driver is offline
I cannot find you on ebay
RENIX Data Logger yellowoctupus OEM Tech Discussion 26 March 15th, 2017 10:22
Renix data charts Lanthanaas OEM Tech Discussion 8 April 25th, 2015 19:04
Innovate LM2 Wideband O2 Sensor/OBD2 Scanner/Data-logger in DC gradon For Sale: Private Party Only. XJ ITEMS ONLY 4 June 26th, 2014 07:17
what is a good OBD II scanner with real time data mmag1982 Jeep Street and Performance 11 September 10th, 2011 06:26
Need A/C low pressure port for Renix pantera1973 SEC For Sale / Wanted Forum 1 June 27th, 2011 15:28
