Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Tow Rigs and Trailers
Tow Rigs and Trailers Hey, not all of our Jeeps are great on the highway. Post here for tech related to getting your XJ to the trailhead.
Old February 27th, 2014, 08:20
Hillbilly XJ's Avatar
Hillbilly XJ Hillbilly XJ is offline
Vari-Lok Progressive Differentals????
I have these in my 04 Grand Cherokee Overland in both the front D30 and rear D44. Is this just another name for a Limited Slip or different?
Old February 27th, 2014, 08:44
donthelegend donthelegend is offline
Re: Vari-Lok Progressive Differentals????
It's an advanced limited slip. I believe it can actually lock completely if necessary. The Quadradrive system claims to be able to send 0-100% torque to any single wheel, and uses a limited slip setup in the tranfercase to determine front-rear torque bias, and Vari-lok in the axles to determine side-to side bias.
See here for more information: http://wjjeeps.com/tcases.htm
Old February 27th, 2014, 15:29
87manche's Avatar
87manche 87manche is offline
probably a gerotor style.
uses the diff carrier as a pump to actuate the clutch pack. Faster the "spiders" turn=more fluid pressure=harder lock up.
edit:
google says it's gerotor
http://www.fourwheeler.com/project-v.../photo-07.html
make sure you use friction modifier.
Old March 2nd, 2014, 09:53
Thank you very much for your reply and explanation of how it works, it took me a few days to get back here.
I'm old and have CRS syndrome or I would have used Google too look it up also
Old March 2nd, 2014, 14:17
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
edit:
Can this be put in to our hpd30?
Old March 3rd, 2014, 09:29
87manche's Avatar
WJ's used LP d30s. I believe the carrier is the same. in the quick google I did it appears the axle shafts are a different length.
so a solid maybe. You'll have to sort out the details.
If the clutch in the gerotor carrier is rebuildable, it may be a pretty awesome DD/full time upgrade.
Old March 3rd, 2014, 09:48
That's what I was curious about because I can only think that the carrier would be the same, it just holds a different cut style ring and such. But then again, I don't know lol
Old March 3rd, 2014, 11:46
87manche's Avatar
it may be worth investigating a WJ at the pick n pull.
or just grabbing the whole D30 and swapping all the stuff to a HP housing.
I think the big problem would be the shafts. I assume that you can use the WJ shafts wit han XJ unit bearing to retain 5x4.5, but I don't know.
The plus side would be that you gain the WJ knuckles and brakes.
Old March 4th, 2014, 08:57
XJLI XJLI is offline
the WJ shafts are longer, so is the actual housing. as long as the pump or whatever isnt specific to the WJ D30 housing its worth the upgrade if you can do it cheap and toss the guts into a HP30. IIRC all the LSD WJs were geared 3.73.
Old March 4th, 2014, 18:48
Talyn Talyn is offline
This is correct
As is this.
Old March 10th, 2014, 17:54
87manche's Avatar
they list different length shafts for the varilok equipped axles. So there's a difference in the carrier significant enough to affect the side gears I suppose. I'd bet that the shaft on the side with the pump is longer so it goes through the pump housing.
That's all conjecture though, as I've not been in a WJ axle with the super fancy diff.
Old March 10th, 2014, 18:10
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Now I'm tempted to rip into a few at the junkyard simply because I can...
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old March 10th, 2014, 18:28
87manche's Avatar
these things with a 242 diff would be pretty fawesome in a DD winter driver.
Old March 10th, 2014, 18:48
kastein's Avatar
Agreed. For sheer availability I think I'll stick to my Durango/Dakota 8.25 rear LSD, but a WJ varilok d30 would be pretty nice.
Old March 10th, 2014, 19:08
kastein's Avatar
Alright so I poked around the parts catalogs a bit.
It's only available as a 3.73 and numerically higher carrier. Sorry, guys with 3.55s and 3.07s... not gonna work out. That includes me, for now *
The WJ LP D30 3.73+ open carrier is the same part number as the same year XJ HP D30 3.73+ open carrier, 0525 2590. So my conclusion is that a WJ Varilok LP D30 3.73+ carrier SHOULD work with an HP D30 as long as you're installing 3.73 or deeper gears.
If you want to order one direct from the dealer, the D30 varilok is 0501 2519AA. They're expensive. The RPO/build sheet code is DSB.
The D44 (not sure which D44 this fits? Could be D44a, regular D44, or super-D44 like the JKs use maybe? I'm not researching it, I don't have any D44s, someone else figure this out) varilok is 0501 2869AA and it also requires installation of a fluid plenum, part number 0501 2870AA and a different cross shaft, part number 0501 5223AA. It appears that installing it also requires different axleshafts from the open diff or trac-lok... open and trac-lok use the same shafts as each other.
* Note: 3.55 and numerically down d30 carriers have a deck height of 1.800... 3.73 and numerically up d30 carriers have a deck height of 2.410. That's a difference of 0.61" and the 3.73 carriers are taller, meaning a 0.61" spacer and ring gear bolts 0.61" longer SHOULD get the job done. Now... I wonder if I can get a friend of mine to make me such a spacer?
Ring gear bolts for the d30 are 3/8-24 RH thread, 11/16" hex head, unknown underhead length since I can't find a reliable source. Aftermarket ones are grade 8, so I bet if I can find grade 8 3/8-24 (UNF) bolts 0.61" longer than the factory d30 ring gear bolts, it should work out nicely with a spacer.
EDIT: Randy's Ring and Pinion lists a "super" (JK and WJ...) d30 as having 7/16-20 ring gear bolts instead of 3/8-24. So this idea may be bunk, though I tend to trust the factory parts catalog over aftermarket sources, and it says the open carriers are the same between the 3.73+ XJ and WJ. It also says the ring gear bolts are the same (0525 2503) for both.
Basically... YMMV. Give it a bit of junkyard researching if you are interested, see what you come up with. Barring axleshaft differences, I think it may work in a deep geared d30, not so sure about a 44.
Rate This Thread:
Progressive Clutch Problem TommyRumble OEM Tech Discussion 20 October 5th, 2010 13:02
The Internationale Progressive Socialists Have Got to Go! joe_peters Political Discussion Zone 0 August 31st, 2010 22:46
Progressive coil sag 87xjWagoneer OEM Tech Discussion 10 August 25th, 2010 22:59
Leupold Vari-X II 3-9x50mm for TRADE, need wheels/tires... SuperSport88XJ Non-Jeeps Items go here. 0 April 30th, 2007 11:21
vari lok or hydra lok torfinn Modified Tech Discussion 6 January 24th, 2004 22:34
