ZJ drag link question
JungleJames
WA
Hey Y'all
My Jeep is a 2000 XJ 4.0
I'm rebuilding the steering linkage and read that ZJ tie-rod is a upgrade and the drag-link is the same. I ended up ordering the ZJ tie-rod and drag-link.
The drag-link I received is about 1 inch longer than the one I removed. I'm wondering if it was manufactured incorrectly. The added length comes from the drivers side threaded end (just the bar side, not including the adjuster sleeve and tie-rod).
Can anyone confirm that they should be the same length?
Thanks for the help
AF1QipNyKAVZb1P107_YyM2uZ3s7tbt5DoQJntnJGesO
Here is a photo of the difference
Hey, I just did the ZJ Draglink/Tie rod swap on my 87 Cherokee yesterday and my stock draglink was the same length as the ZJ draglink. Were you able to get this figured out?
-Mike
The ZJ and XJ Factory draglinks are the same. The tie-rods are the same too except for from a V8 ZJ which have a bigger, solid tie-rod, a definite upgrade.
