Old June 10th, 2009, 17:57
vajeeper vajeeper is offline
Sudden Drop in gas Milage
I have a stock 97 xj country. Within the last month my gas milage has dropped from 320 miles per tank to about 240 per tank. I havn't done anymods to my jeep at all. please help me out if you know anything.
Old June 10th, 2009, 18:00
Re: Sudden Drop in gas Milage
for a little over a year when i start my jeep and first start going the engine will bog down and i can fix it by leting off the gas or by reving in neutral. Im not sure if it is the cause of the new problem or this problem has gotten worse.
Old June 10th, 2009, 18:29
joe_peters joe_peters is offline
Loss of mpg:
1. O2 sensor causing run rich.
2. Cracked exhaust header upstream of O2 sensor, O2 reads lean, runs rich.
3. Coolant Temp Sensor bad, reads engine cold, computer makes it run rich.
4. Missing thermostat, stuck open thermostat, wrong temperature thermostat, engine is not warming up and runs rich.
5. Belt driven accessory failing, too much drag on engine, poor mileage.
Check these articles in JP Magazine:
http://www.jpmagazine.com/projectbui...eep/index.html
http://www.jpmagazine.com/projectbui...t_2/index.html
http://www.jpmagazine.com/projectbui...ter/index.html
Old June 11th, 2009, 09:17
I think i will start with the O2 sensor and see what happens after that...is it better to replace the front one or the rear to try and troubleshoot the problem...can an O2 sensor be tested?
Old June 11th, 2009, 19:20
Testing the O2 sensor is kind of a PITA--it has different voltage outputs at different temperatures and different o2 levels.
I would replace the the upstream (front) O2 sensor first.
Old June 11th, 2009, 21:17
jujuscisyn jujuscisyn is offline
sudden drop in mileage I immediately look for the o2 sensor or a plugged cat
99 XJ Sudden temp rise and sudden drop shortly after jjnavarro OEM Tech Discussion 28 August 12th, 2010 10:59
Sudden drop in MPG sjx40250 OEM Tech Discussion 6 March 19th, 2007 06:32
SUDDEN TEMP. GUAGE DROP SJB64 OEM Tech Discussion 1 January 1st, 2007 06:05
sudden drop in fuel economy? Kejtar OEM Tech Discussion 25 April 13th, 2006 15:52
Sudden gas mileage drop Land Yacht OEM Tech Discussion 3 August 20th, 2004 09:54
