Old January 7th, 2009, 02:32
Joepoppa1's Avatar
Joepoppa1 Joepoppa1 is offline
Frame stiffener install pointers
I am going to be buying some T&T frame stiffeners here soon, and was wondering if there are any pointers that some of the guys out there that have installed them, may have. Do you have to shore up the chassis to try and get this thing straight, or do you just let it sit naturally on the wheels on the flat ground? I know I have to take it to bare metal to weld it, do you reccomend using some weld thru primer or just grind where I am going to weld? Do you reccomend drilling some extra holes for extra roset welds? Any advice that y'all have would be appreciated.
Old January 7th, 2009, 03:41
wim hoppenbrouwers's Avatar
wim hoppenbrouwers wim hoppenbrouwers is offline
Re: Frame stiffener install pointers
-Get stiff!- from Dirk Pitt 09-05-2008 and Brianho13 09-20-08.
Search to this post! and you can see nice holes.
Nice pics too.
Old January 9th, 2009, 04:21
Joepoppa1's Avatar
Nice, thanks for the help! That is a nice setup.
Old January 9th, 2009, 08:20
micahtbyrd micahtbyrd is offline
Just drill some 1/2 holes every 6 to 8 inches, top side and bottom, leave the jeep on level ground, and clean the frame rails really well. The underbody coating burns really well. Make your welds good, take your time, and just stitch things up by welding in different areas, don't concentrate the heat all in one place. If you are using the tnt stiffners, just drop your crossmember, and put the stiffners in then bolt the crossmember back up and weld away. Give your self some time, I did mine over two days. after your don clean and paint. and use self tapers to reattach the ebrake cable box. Micah...
Old January 9th, 2009, 10:07
Mtb Jak's Avatar
Mtb Jak Mtb Jak is offline
is it proven you need the holes to weld it up?
i still am not convinced..
THX for the self tapper thing.. one of the things i was concerned about
Old January 9th, 2009, 10:51
bcmaxx's Avatar
bcmaxx bcmaxx is offline
I just finished installing mine from hd, I did mine on the hoist, not sure if this was good or bad? The install went very well, we used a floorjack, and some peices of 2x4 to get them tight to the chassis rails, and c clamps to suck them tight and welded them in. I think the rossettes really help strengthen things. Now I have something really solid to mount my super rails to.
Old January 9th, 2009, 11:40
JeepFreak21's Avatar
JeepFreak21 JeepFreak21 is offline
Here's my write-up:
http://www.bsfab.net/?p=16
I DON'T recommend using the same "weld-through" primer I used!
HTH,
Billy
Old January 9th, 2009, 13:50
ehall's Avatar
ehall ehall is offline
I've been thinking about bolting mine on with nutserts. What do you guys think about that.
my '91 beater rebuild
Old January 9th, 2009, 14:32
If I was going to bolt them on, I would use these: http://www.currieenterprises.com/ces...t.aspx?id=2539
I think the other style would be a waste of time if it were only bolted on. (JMHO)
Billy
Old January 9th, 2009, 15:55
crazyjim's Avatar
crazyjim crazyjim is offline
Billy
Even that style bolted on wouldn't do jack sh*t.
I'm running TNT's, perimeter welded and rosette welded, with the T&J (Currie) stiffeners over the tops of them, bolted to the LCA mount, welded just above, bolted to the leaf spring box, and welded in 6 points along the frame.
Coming from someone who started with the TNT's. I wouldn't even install them if you aren't going to drill plug weld holes. IMO even with the perimeter welding and the plug welding, they STILL weren't stiff enough for me. I still had creaks and cracks in my dash when I'd drive it.
After that I installed the TMR front frame plates, and the T&J (Currie) stiffeners and can tell a WORLD of difference!
Old January 9th, 2009, 15:57
crazyjim's Avatar
Here's how I installed my TNT's with the help of Cal & Willy51!
mscans's Avatar
mscans mscans is offline
Here's my write-up:
HTH,
Billy
nice writeup, that paint is amazing for gates and chain link fencing, but it's not a weld thru primer, i cant believe you even welded through that at all.
very thick painty stuff.
your build looks clean though.
Old January 9th, 2009, 16:01
Thanks. FWIW it does say, "For weld-through applications" on the back as well as on their website
Billy
Old January 9th, 2009, 17:29
Maxwell's Avatar
Maxwell Maxwell is offline
"Even that style bolted on wouldn't do jack sh*t."
that, my friend was one of the very first stiffener designs produced, it was designed for the JeepSpeed circut inwhich some high speed 'give' was expected through desert terrain, they also tied the front suspension & rear suspension together, almost as a subframe, but lightly unengineered as such using round tube. It's been on the market long before long arms or drop brackets and still has it's place, lets not rag on your grand-daddy, todays stiffeners have just as many flaws which would in comparison be like putting a koozy on a beer can not to mention the fact that the cherokee could never be sold on a used car lot again, most installs end up looking like a poor attempt at a unibody repair at best.........
Old January 9th, 2009, 18:25
crazyjim's Avatar
No no no I'm not ragging on them AT ALL. Matter of factly, those tubular style "Sub frame connectors" made some of the most notable improvement on my Jeep. I AM in fact running them after all. For what it's worth, I used to argue the same thing to people when I had my camaro. People would BOLT on subframe connectors, thinking they were doing a world of good. When in fact, in the long run, you would notice no difference whatsoever as the bolt holes would widen and oval. Your best bet is to weld them on period.
All I was saying was that bolted on, in only two locations (which is how many places they bolt) would do very little if anything at all for strenthening the subframe. I noticed however more of a difference with the currie/t&j style than I did with the TNT's. That could have been because I had both installed at that point though.
They need to in my humble opinion, be welded at multiple points along the frame to make the most difference... like I did here and also like what is recommended.
You can see my full write up here:
http://naxja.org/forum/showthread.ph...ght=stiffening
You can also see the write up on TNT stiffeners here:
http://naxja.org/forum/showthread.ph...ght=stiffeners
And TMR frame plates here:
TNT Customs long arm and frame stiffener install KG6ZJM Modified Tech Discussion 33 February 23rd, 2018 19:57
RR adjustable track bar and frame stiffener kit 99greenjeeper Modified Tech Discussion 10 December 29th, 2008 17:02
TNT frame stiffener thickness? Jeff 98XJ WI Modified Tech Discussion 6 March 28th, 2007 19:34
Rockkrawler long arms and frame stiffener 00XJFAN Modified Tech Discussion 2 December 8th, 2006 20:59
Is a frame stiffener ever overkill? jmsull Modified Tech Discussion 6 March 29th, 2006 07:31
