Old September 11th, 2008, 14:58
k.smith904 k.smith904 is offline
Crankshaft Position Sensor
So I brought my 87 renix into the local dealership the other day after i couldn't figure out whats wrong with it and they told me what I pretty much already knew. They said it was one of 3 things:
1. Crankshaft Position Sensor
2. Throttle Position Sensor
3. Ignition Coil
Heres my question: How hard is it to install these by myself, i'm not an idiot, but certainly not a gearhead either.
They quoted me at $170 parts and labor for the CPS and install. Too high?
How much would each part run me if I were to order them myself? (Ballpark)
Old September 11th, 2008, 15:01
UNCC_99XJ's Avatar
UNCC_99XJ UNCC_99XJ is offline
Twisted Up
Re: Crankshaft Position Sensor
In order of easiness (IMO)
3...2....1.
Just did a CPS on a 88 last weekend....sensor cost $35 at Advance Auto and took an hour or so to install (never having done one and it's in a tight spot).
TPS is really easy to get to.....I don't recall the price of the one for my 99 off the top of my head...for some reason $60-70 rings a bell...but don't quote me on that.
Ignition Coil (we tried first on the 88 last weekend) was about $55 from Advance and super easy to install.
What are the symptoms of you problem?
-Timbo -
-'99 Sport, RE 4.5" and a few other things
-'13 Performance Blue Ford Focus ST. DD & Race Car.
-'17 Ruby Red F150 Lariat. Tow rig and occasional DD
Old September 11th, 2008, 15:06
no start, it will randomly start up, then I drive it around the block, park it, and when I try to crank it up 10 min later it won't start. I've cleaned the grounds and all the sensors as good as i could.
Old September 11th, 2008, 15:41
XJ Stryker's Avatar
XJ Stryker XJ Stryker is offline
WHO DAT!
Quick fix just unplug then replug in the CPS... Maybe blow it out with some canned air. The connectors on those are the known cause for going bad. I had to do it on my wifes rig about 2 months ago cause it wouldn't start and has started fine everyday since then.
Old September 11th, 2008, 19:09
88 Wagonman 88 Wagonman is offline
The renix will start with the TPS unplugged, and definately try unplugging the CPS and cleaning the connector as XJ Stryker suggested. Did the mechanic even bother troubleshooting your problem, or is this a cash register diagnosis? I can't stand it when "professionals" start guessing and throwing parts.
Old September 11th, 2008, 19:28
Tito_73* Tito_73* is offline
CPS is the way to go starting from the begining. The wiring goes bad on 87-90 Renix XJ's. Google Jeep Reference J007 it is definately a needed service procedure for Renix XJ's. An easier but more time consuming way to replace the CPS is to support the trans & transfer case with a floor jack & a block of wood @ the pan. Then remove the crossmember + front driveshaft. Lower assembly and use 7/16" or 11mm socket with extensions to remove the CPS. Unplug and remove. You can do it by routing your had all the up the bellhousing with the transmission bolted up but it's a bitch. Good luck with your XJ.
Old September 11th, 2008, 23:19
MJmk's Avatar
MJmk MJmk is offline
Are they just changing the CPS only, or are they doing the Technical Service Bulletin to replace the CPS and wire it directly to the ECU?
The TSB is for 87 and 88 only. To tell if the TSB has been done already, the connecter for the CPS will be plugged into a small wire harness that goes to the firewall right underneath where the main harness passes through. If it has not been done, the CPS will still be plugged into the fuel injection wiring harness.
More info:
TSB 18-51-88
Parts:
83100066 kit for automatic trans, has new CPS, harness, and dust cover.
83100063 kit for manual trans, has new CPS and harness.
Instructions are not included with the part, must print out the TSB.
My copy is old so part numbers may have changed, and hopefully still available if you need them!
Old September 11th, 2008, 23:25
dfete91's Avatar
dfete91 dfete91 is offline
It's all easy stuff. 30 minutes labor. All 3 of those parts can be tested at Autozone for free.
Old September 11th, 2008, 23:28
dfete91's Avatar
I'll sell you all of those parts off the same year model for 30 bucks.
Old September 12th, 2008, 05:41
89xj 89xj is offline
also, the tps on 87-90 needs to be adjusted with a voltmeter/mutlimeter to factory specs. its not plug and play like the 91-and up, unless you get lucky on the install.
Old September 12th, 2008, 09:53
mjma's Avatar
mjma mjma is offline
CPS is a PITA to get to...unless you've got the hands of a 12 year old girl!!
Old September 19th, 2008, 12:56
well im getting the heep towed back home today so I'm gonna try to mess around with the CPS and try to clean it and the TPS the best I can. Then if that doesn't work I'll start throwing parts at it.
Is there anything else that is common in the renix xj that would cause a random no-start?
Heres what I'm going to replace so far:
CPS
TPS
Ignition Coil
Spark Plugs
anything else I should grab, or try?
Old September 19th, 2008, 13:00
swbooking's Avatar
swbooking swbooking is offline
I would bank on it being the CPS. Thats a quick fix. all you need is an 11mm (or 7/16") socket (swivel would be good) a long extension and a ratchet.
two bolts off, swap it, and two bolt back on. done.
Old September 19th, 2008, 13:03
alright thanks, I'll let you guys know the verdict later on...
Old September 19th, 2008, 13:24
Mbjeep91's Avatar
Mbjeep91 Mbjeep91 is offline
i agree with swbooking, ive changed quite afew CPS at work. Really pretty simple to do assuming the bolts come loose pretty easy. Good Luck!
Crankshaft position sensor 95 vs 97 crawll OEM Tech Discussion 1 February 9th, 2008 12:53
CPS (Crankshaft Position Sensor) - Thanks Everythingoutdoors OEM Tech Discussion 1 May 19th, 2007 08:47
Crankshaft Position Sensor? 89Cherokee4x4 OEM Tech Discussion 8 December 3rd, 2006 09:16
Speed Sensor/Crankshaft Position sensor??? jacobyj2 OEM Tech Discussion 3 August 30th, 2006 16:12
Crankshaft Position Sensor on '88 LuckysHunter OEM Tech Discussion 11 April 11th, 2006 15:20
