Old August 5th, 2008, 15:12
rockjockphatts rockjockphatts is offline
Question electric fan
Does anyone know if the electric fan is somehow linked to the air conditioning. My A/C has a leaky coil and as such doesn't work. But it seems lately that my electric fan does not kick in anymore. So, are they related or do I have another item to put on the ever-growing to do list?
Old August 5th, 2008, 15:29
cambosoup99's Avatar
cambosoup99 cambosoup99 is offline
Re: electric fan
electric fan supposed to come on when the a/c is on.
Old August 5th, 2008, 16:12
Muad'Dib's Avatar
Muad'Dib Muad'Dib is offline
Re: electric fan
This is correct, however the reverse is not true.
I hit a deer in my 90, and just havent had time to recharge my A/C system. So for now its in-operable yet my stock electric fan still comes on when its suppost to. If yours isnt, then look into a new CTS.
Old August 5th, 2008, 21:40
Re: electric fan
what a CTS?
I probably already know, but regardless, I'm glad to know that they're connected. Thanks guys!
Old August 6th, 2008, 00:00
gradon's Avatar
gradon gradon is offline
Re: electric fan
The Coolant Temperature Sensor, not the coolant temp sender, not the crankshaft position sensor, and not the camshaft position sensor.
Old August 6th, 2008, 09:09
92xjsp 92xjsp is offline
Re: electric fan
Electric fan is programmed to come when EITHER (1) AC is turned on, or (2) AC is off but engine temp reaches a certain point (I think 210).
Old August 6th, 2008, 15:18
Banditt007 Banditt007 is offline
Re: electric fan
try just unplugging the connector that goes to the fan itself and jump 12v to one and ground the other wire. and see if it works. no point running around in circles if it doesn't work in the first place. my e-fan didn't work and it turned out it was all full of corrosion on all the copper electric tracks and where the wires were soldered to it..basically corrosion everywhere. i scrapped it/sanded it all off, re-soldered the wires and it works perfect. saved me $80-120 depending on where you would buy a new one.
Electric fan mpro1 OEM Tech Discussion 1 June 27th, 2007 14:13
WTB: Electric Fan!! jeepspeed93 SoCal For Sale 0 April 28th, 2007 02:37
electric fan help xrayjeeper83 Modified Tech Discussion 8 April 15th, 2007 01:52
Electric Fan JeepsCherokee Jeep Street and Performance 4 January 6th, 2006 15:48
OEM to Electric Fan techno1154 OEM Tech Discussion 13 May 10th, 2004 18:55
