Old November 18th, 2004, 14:39
Rootehound Rootehound is offline
Heat Problem
My '87 4.0 pumps out luke-warm heat from below the dash. However, if I set it so the heat comes out the dash vents, it seems to be hotter. It runs at a constant 190 degrees, there doesn't seem to be a heater-core leak, and the blower works fine. Any thoughts?
Old November 18th, 2004, 16:39
jneary's Avatar
jneary jneary is offline
Re: Heat Problem
try removing the hoses from the heater core and back flushing the heater core and see what happens, it may be stopped up.
Heat and A/C problem FreemansXJ OEM Tech Discussion 2 December 20th, 2003 04:11
over heating problem MCD OEM Tech Discussion 12 December 9th, 2003 17:35
Need Help - Stud/Hub problem MarkF OEM Tech Discussion 3 December 6th, 2003 22:56
"new posts" problem imma honky User Support, Questions and Suggestions 1 December 6th, 2003 09:54
Hey crash ..leaf spring help VegasAnthony Sierra Chapter 7 September 6th, 2002 14:32
