Old July 16th, 2019, 17:12
JWK2KXJ's Avatar
JWK2KXJ JWK2KXJ is offline
2000 XJ Gas Tank Compatibility
Some decided to break into our property and drill holes in my gas tank to steal all the gas out of it. (Doesn't anybody know how to siphon gas properly like in the old days?)
My XJ is a 2000 with the multilayer HDPE (plastic) 20 gallon fuel tank with the fuel sender assembly hole in the top of the tank that apparently nobody sells anymore (I saw one site that listed it as discontinued by Mopar). I'm keeping my eye on the local pick-your-part yards, but I was wondering: Did Chrysler use the same tank in any other model Jeeps or trucks? The local yards are currently light on their supply of 98-01 XJs. So I want to widen my search a bit if possible.
Also, if anyone in SoCal happens to have a 98-01 fuel tank lying around in need of a good home, hit me up. I'd love to take it off your hands (for reasonable compensation, of course).
Old July 16th, 2019, 18:19
Anak's Avatar
Anak Anak is offline
Stranger
Re: 2000 XJ Gas Tank Compatibility
I think you may be able to run a ZJ tank as well. That would be '93 to '98 Grand Cherokee. Those may be a bit more plentiful in the junkyards. At least gives you another option.
There is a thread around here on that topic. Since you are already using a tank with the threaded top/drop in pump assembly it should be easier than for those who are trying to convert a '96-down XJ.
ETA: Here is one thread that may be of interest to you. Brings up some of the issues you will run into, but not finished yet: https://www.naxja.org/forum/showthread.php?t=1154068
Old July 16th, 2019, 20:48
JWK2KXJ's Avatar
Awesome! Thanks!
Old July 18th, 2019, 09:33
JWK2KXJ's Avatar
Here is another thread that explains the use of the copper tube to extend the capacity of the ZJ tank to 25 gallons (from 23, which is already an improvement on the XJ's 20 gallon tank capacity):
https://www.naxja.org/forum/showthread.php?t=1131307
Old July 18th, 2019, 10:09
RCP Phx RCP Phx is offline
That's the thread I used to step up to the plate on a ZJ tank.
Old July 18th, 2019, 16:24
XJensen's Avatar
XJensen XJensen is offline
I have a ZJ tank in mine with a zj skid. everything bolts right up
-------- www.4x4TrailMaps.com --------
PCM compatibility: 2000 PCM in a 2001 XJ? anthrax323 Modified Tech Discussion 7 February 26th, 2015 16:02
Gas tank skid for a 2000 XJ xjtrailrider Modified Tech Discussion 19 January 12th, 2013 19:45
Gas Tank Skid Compatibility bdiamond OEM Tech Discussion 2 March 15th, 2009 21:00
gas tank compatibility jeepnuts311 OEM Tech Discussion 7 May 20th, 2007 17:49
Gas Tank Skid - Tow Hitch Compatibility woodrock03 OEM Tech Discussion 7 November 19th, 2003 07:30
