Old December 13th, 2019, 21:38
Jeepmedic46's Avatar
Jeepmedic46 Jeepmedic46 is offline
Fuel smell upon starting
There is a strong fuel smell upon starting my 2000 XJ. Jeep has the 4.0 engine. It is a replacement engine put in by the previous owner. Also the gas mileage is terrible. I go down the street and I use about a quarter of a tank. Thank you, new to all this and looking for places to start looking.
Old December 14th, 2019, 06:25
RCP Phx RCP Phx is offline
Re: Fuel smell upon starting
Crawl under/over your vehicle right after staring it and look,smell , and feel for leaks. With the exception of corroded lines there are not to many places fuel could be coming from.
Old December 16th, 2019, 07:13
Evan03 Evan03 is offline
Most likely leaking on line supplying fuel to injectors at the front of the motor.
Old December 16th, 2019, 08:18
Skwerly Skwerly is offline
Also in the engine bay. That's a scary place to be squirting raw fuel.
Old December 16th, 2019, 12:56
techno1154's Avatar
techno1154 techno1154 is offline
Or maybe you are in cold weather so the cold start device is adding extra fuel to keep the engine running until it warm up enough.
The above posts have some great advice. A once over visual is needed regardless. I do that to my XJ regularly both in the engine compartment and under the vehicle with the engine running.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old December 16th, 2019, 14:19
Ivan's Avatar
Ivan Ivan is offline
I Jeep, therefore, I am..
The Charcoal Emission canister located by the left rear wheel well, has been a source for fuel leaks / smells in the past.....
Follow your fuel lines there...you should be able to find it behind a cover...
Old December 16th, 2019, 16:19
Not finding any leaks, fuel smell only seems to be when the Jeep is cold. Does get horrible mileage. Getting 4 miles to the gallon. I will check the canister. Could it be a clogged injector? Will double check what people have said above.
Old December 16th, 2019, 16:26
Black1990jeep Black1990jeep is offline
Rich operation will kill the catalyst, 4 mpg is very rich if indeed that extra fuel is being sent into the motor.
On my jeep, the fuel pressure regulator leaked.
Avoid driving until fixed, you may have a fire hazard, of may end up killing the catalyst.
Old December 17th, 2019, 07:28
Taking everyone’s advice and not driving the Jeep.
Old December 17th, 2019, 10:08
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
I would use a fuel pressure gauge to monitor the pressure and see if there is a leak, If so, without starting the engine, have a helper cycle the ignition key occasionally to build fuel and maintain fuel pressure, while you examine the fuel system from the tank up to the injectors. Wiggle the fuel line at any spot you can, looking for tiny seeps or drops of fuel. Not having the engine running reduces the chance of fire and the lack of heat and blowing air makes finding the leak easier.
If you smell it, there is a leak somewhere.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old December 17th, 2019, 10:16
Yeah, 4 MPG is bad for a built big block V8. I sure hope you find the issue soon. What a bummer.
Old December 17th, 2019, 17:13
Worse considering itís a stock 4.0. I had a 86 with a built 302 and ran 33s and got better mileage.
Old December 18th, 2019, 19:18
I checked out the fuel lines and found no leaks. Engine seemed to be running rich. I changed the plugs and found 3 of them with the bottom of the plugs smashed. Thinking the other owner put them in to tightly. Engine seems to be running better and no fuel smell.
Old December 19th, 2019, 06:58
Anak's Avatar
Anak Anak is offline
Stranger
Glad you found it.
Surprised you didn't have codes for at least misfires.
Baby it's cold outside.
Old December 19th, 2019, 07:37
If they're installed to tight the contact contacts the piston and smashes the spark plug gap closed or tighter then 035 and grounds out on piston creating a misfire condition that is unrecognized by the human while seated in the drivers seat..
Fuel smell karstic OEM Tech Discussion 1 January 29th, 2007 21:29
Fuel smell? MrMom OEM Tech Discussion 6 January 11th, 2007 14:53
Cold Starting Fuel Exhaust Smell XJ jeepsrock OEM Tech Discussion 25 June 21st, 2005 15:06
Fuel smell geepers OEM Tech Discussion 2 January 20th, 2004 07:16
Fuel smell.. RINGKONG OEM Tech Discussion 3 July 14th, 2003 09:09
