Old March 26th, 2005, 13:41
Flyfisher's Avatar
Flyfisher Flyfisher is offline
Evil Shackle Bolts
Putting a Teraflex greasable rear leaf spring shackle in my '88 XJ today. It's currently soaking in PB Blaster. My question is does the shackle-to-body bolt have a nut behind it that needs to be accessed to remove the bolt? I know the front spring-to-body bolt has a "blind nut" that is welded to the body (it was also evil when I did my new springs for the lift)...just wondering about the rear one.
If the nut needs to be accessed for removal...how do I get to it? Guy at the tire store suggested removing the carpet/floor in the rear!
Thanks in advance for any advice.
Old March 26th, 2005, 14:09
BruteXJ's Avatar
BruteXJ BruteXJ is offline
Re: Evil Shackle Bolts
No nut back there to hold on to. It's just a reeeeeeeealy long bolt that takes forever to wrench out. At least on a '00 and a '99. Probably the same.
Old March 26th, 2005, 15:14
johnnyc's Avatar
johnnyc johnnyc is offline
I just put 1.5" Teraflex shackles on a couple of weeks ago. That bolt came out pretty easy. Just have to relieve the tension on the spring with a floor jack.
Old March 26th, 2005, 21:53
Flyfisher's Avatar
Thanks for confirming "no nut" to wrench on. Got 'er done today...just a lot of PB Blaster...soaking...more PB, then a cheater bar on the wrench. Went back in easy though...after giving the "evil bolt" a good cleaning and light lube.
The 1.5" shackle lift leveled the jeep nicely. I think the rear springs of my 3" Skyjacker lift (new leafs, not AAL's) had sagged a little or sagged due th the fact that I carry about 50 lbs of gear and a 31" spare and high lift jack back there.
All's well than ends well!
Old March 27th, 2005, 17:36
BruteXJ's Avatar
Congratulations on conquering the "Evil Bolts".
Broken motor mount bolts BIGTSV Modified Tech Discussion 8 February 12th, 2005 00:19
bolts, bolts, and more bolts clay Modified Tech Discussion 14 October 7th, 2004 15:49
Rear Shackle upper bolts red91 OEM Tech Discussion 3 August 13th, 2004 11:52
Shackle, Leaf Spring bolts seized in bushing? korda Modified Tech Discussion 9 June 22nd, 2003 10:44
Torque on shackle bolts andyr354 Modified Tech Discussion 2 May 12th, 2003 20:01
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
