Old September 14th, 2020, 06:56
blu3fan's Avatar
blu3fan blu3fan is offline
Re: High NOX every year
Okay.
New plugs installed.
Timing at distributor checked. I am running little retarded 1-2 degrees like normal.
I kinda don't trust gas to have 91 octane with covid going on. and I can literally hear the stroker knocking/pinging at little at idle.
I mixed up some 110 octane~ and added a gallon to my almost full tank (normally I use this for my 80's honda motorcycle for long trips since it burns so much better/get +20mpg more). should bump up the octane a bit.
Gonna take her on a 30/1hour drive then go for smog today.
Will post results.
Old September 14th, 2020, 10:32
blu3fan's Avatar
High NOX every year
Danm so close...
Sent from my Pixel 3 XL using Tapatalk
Old September 14th, 2020, 10:34
blu3fan's Avatar
High NOX every year
I'm now at the muffler shop getting the new cat welded on
Old September 14th, 2020, 11:23
blu3fan's Avatar
High NOX every year
Passed with new cat. I hope my test results help others
Old September 14th, 2020, 19:07
asymptonic asymptonic is offline
Wow, the cat really cleaned everything up!
1998 4.0 I6, AX15, NP231
Old September 15th, 2020, 11:23
blu3fan's Avatar
Yeah.
I guess those high flow magnaflow cats last about 50k or 8 years.
Old September 16th, 2020, 09:57
Black1990jeep Black1990jeep is offline
if you had the cat bolted on rather than welded, well then the cat can be removed and kept in great like new condition for a long time. a lesser cat can be installed for non test days. dont beat up your expensive cat off roading!
Old September 17th, 2020, 12:22
89Mock 89Mock is offline
Looks like a good catalytic converter would have been the best option. 50k doesn't seem like much for a cat, but I'm sure it wasn't designed to be off roaded. Still....50,000 miles seams weak.
Proposal to waive one-year requirement for BOD elections this year only. SandySteve Intermountain Chapter 26 November 17th, 2013 16:46
What the best year stock front XJ axle, swapping a low pinion for a high pinion? pajeepman OEM Tech Discussion 9 October 18th, 2010 21:49
20 year old XJ being cranky, inttermittant high/low Idle the_bandit87 OEM Tech Discussion 2 June 7th, 2007 11:04
OLDER YEAR ARB BUMPER FIT ON A NEWER YEAR CHEROKEE C85D4x4 Modified Tech Discussion 6 September 26th, 2006 17:32
New things i've done this year and my plans for next year ROBZ95Xj North Atlantic Chapter 3 December 29th, 2005 09:33
