Old July 19th, 2020, 16:02
Saudade's Avatar
Saudade Saudade is offline
Re: Meh a/c
No worries. Just make sure the valves on the manifold gauge are closed before you open the service valves.
1988 Laredo 2wd Auto, AKA "Grey Ghost", 206K
Old July 19th, 2020, 16:39
blu3fan's Avatar
blu3fan blu3fan is offline
Re: Meh a/c
yeah 100%.
I've done other a/c systems on car's before this had me sooo stumped... now that I understand it its a way cool thing to have.
Old July 19th, 2020, 17:42
Agreen Agreen is offline
Re: Meh a/c
Wow I've honestly never come across that style before. 15 years of being a professional auto tech and that's a first. It's awesome to learn something new!
Old July 19th, 2020, 18:13
Saudade's Avatar
Re: Meh a/c
That's why we're here.
Had my XJ for 20 years and still learn something new every now and then.
Old July 26th, 2020, 07:46
blu3fan's Avatar
Re: Meh a/c
Okay. some updates.
#1. the low side port was completely seized and I have to really mess with it to get it moving. That is now resolved.
However this raises some questions.... such as. if the low side port was seized. the a/c guy 100% filled from the high side.
T.T
After messing with it today. still cant get this thing to fill...
Pulled vaccum. -30hg did not change in 60mins.
Both Gauges show pressure when car started.
R12 Valves set halfway.
Bypassed relay. clutch engaged.
Tried to fill a Can. (low side)
Can got cold. Did not fill.
Am I like missing something?
Old July 26th, 2020, 07:47
blu3fan's Avatar
Re: Meh a/c
when I say "can got cold didn't fill"
Can we running for 20mins on the first can.
it still weighs almost the same as the new can.
I feel like I'm going crazy here...
Old July 26th, 2020, 08:30
blu3fan's Avatar
Re: Meh a/c
I did some more messing with it.
I cant seem to get high side to show pressure. with the valve set to halfway.
so this leads me to believe compressor might have tanked.
Will update with more info.
Old July 26th, 2020, 09:25
Saudade's Avatar
Re: Meh a/c
What pressure did they show? With the system evacuated, there should be no pressure since there's nothing to pump.
Old July 26th, 2020, 09:30
blu3fan's Avatar
Re: Meh a/c
0 high side pressure.
30 low side
Old July 26th, 2020, 09:34
Saudade's Avatar
Re: Meh a/c
30 low side
What gauges are you using? Can you post a pic?
Zero on the high side is atmospheric pressure. At rest (ac off), both high side and low side should read the same.
Old July 26th, 2020, 09:35
blu3fan's Avatar
Re: Meh a/c
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I bought these
Old July 26th, 2020, 09:36
blu3fan's Avatar
Re: Meh a/c
With Gauges hooked up after removing the can of r134a. Im now showing 0 on both sides with gauges hooked up sealed. no can attached.
Old July 26th, 2020, 10:12
blu3fan's Avatar
Re: Meh a/c
Im gonna do some messing with the r12 valve. I have it 100% centered. but maybe I'm still not getting into it.
Old July 26th, 2020, 13:01
Saudade's Avatar
Re: Meh a/c
Sounds like you have no refrigerant left.
I checked on a spare valve I pulled from a junk yard a while back. Both take about 9 1/2 turns to go from "Back seated" (normal use) to "front seated" (isolate compressor). So when you "open the valve" for servicing, turn the stems about 4 turns.
Back Seated
Front Seated
Mid (servicing)
Old July 26th, 2020, 13:51
Re: Meh a/c
A bad compressor is possible at this point. There's a reason the low pressure switch is there. You may have bypassed it so much that it caused compressor damage.
Take a trip to the JY and grab some AC lines. Or maybe a place that makes hydraulic hoses can make you some new ones pretty cheap. Either way, I'd be ditching those valves.
