Old January 12th, 2018, 18:17
HttpWayne HttpWayne is offline
Re: AW4 whining noise
Just speculating, but one of the previous persons mentioned he had a transmission flush and he suspected the torque converter. Do transmissions flushes effectively clean out the torque converter? It might be worth the effort to pull the transmission to get that guy cleaned out if you have a transmission flush done. It doesn't seem like it gets good fluid flow by design and after a few decades and a few flushes, assuming it had them like it was supposed to, it probably has very old fluid in it.
Unless they do actually participate very well in the flush. Then nothing I said even matters
Old January 20th, 2018, 10:33
MG2000XJ's Avatar
MG2000XJ MG2000XJ is offline
Paying attention to this as well. Mine has developed a whine recently and the shop immediately said, rebuild it. Same symptoms, same whine, same bellhousing area. Lots of comments say just swap in the lowest mileage aw4 you can find. If I come up with an answer I will report back.
Old September 22nd, 2018, 17:43
azupcountry's Avatar
azupcountry azupcountry is offline
Going to keep this post on the road...
My 96 which I've had since 97 with 232k on the clock has had this whine for at least the last 4-6 years. I continually check the fluid level, do the maintenance, ...but nothing ever changes. Shifts fine and still getting 18-20 mpg with compressions 170-180. I too have tracked it to the bell housing and suspect either the TQ or the pump.
I don't like it but it keeps running fine on my daily 60 mile round trip commute.
Here's to finally being able to answer this one some day.
Old February 23rd, 2019, 16:15
BALTANAKT BALTANAKT is offline
Welp, I've begun to notice a similar whining noise on cold winter mornings here in CO. It still shifts fine, the noise is just a little disconcerting. I put in a new torque converter last year and fluid looks good. Will keep checking it regularly.
Old September 12th, 2020, 06:42
HuntFishCampXJRay's Avatar
HuntFishCampXJRay HuntFishCampXJRay is offline
Well after reading through all of this it seems to be that I'm going through the same issue . Has anyone ever discovered what was going on or had this issue before. I have done everything I can to this transmission to no avail
Old September 12th, 2020, 06:43
Next thing I'm going to do is just buy a brand new rebuilt transmission
Old September 12th, 2020, 08:17
lawsoncl lawsoncl is offline
You're ready to drop $1600 because you hear a whine? As mentioned, rule out any accessories by pulling the serpentine belt. The AW4 trans is a pretty robust transmission, and usually any shifting issues are sensors or solenoids that are relatively easy to replace. They easily go 3-400k miles
whining noise... Robs92XJ OEM Tech Discussion 3 June 21st, 2008 12:13
Whining Noise?????? sprngfldxj OEM Tech Discussion 6 February 2nd, 2007 21:07
whining noise Mikel OEM Tech Discussion 5 March 11th, 2006 12:04
Whining noise from motor jeepboy12001 OEM Tech Discussion 7 September 16th, 2005 20:43
whining noise, need help ASAP CStamm OEM Tech Discussion 7 October 20th, 2003 13:26
