Old September 29th, 2021, 09:50
Mad Steez's Avatar
Mad Steez Mad Steez is offline
Lovely Noise From Drivetrain
Hi everyone!
2000 XJ 4.0 Auto 4x4 - RE 3.5 lift on 31s, 242 t case, 8.25 limited slip (factory) rear and D30 front, 230,000 all original miles, hack n tap. New plugs and oil/filter.
Buddy of mine just sent me this vid of his XJ. What would be causing this noise? Im thinking transmission issue.
He just got it home and it started making that noise. We know the front driveshaft is out, steering box is leaking and rear main is leaking as well. He picked it up cheap cheap.
Thanks 🙂
Let me know if you need more info!
https://youtube.com/shorts/hRJHauFK4b4?feature=share
Old September 30th, 2021, 18:28
Evan03 Evan03 is offline
Tourge converter bolts might be coming out. Doesn't sound internal to me. Though im not sure what internal might sound like
Old October 12th, 2021, 11:21
Mad Steez's Avatar
Thank you!
Since this post the jeep starts but does not move in drive or reverse and that noise is constant.
It is just sitting now until we can get around to it.
Old October 12th, 2021, 11:24
Mad Steez's Avatar
Would a broken flex plate cause the jeep to run but not move?
Old October 12th, 2021, 12:36
RCP Phx RCP Phx is offline
Re: Lovely Noise From Drivetrain
That sounds like the fan blade hitting something possibly even the radiator.
Old October 12th, 2021, 14:19
stockerwithalocker's Avatar
stockerwithalocker stockerwithalocker is offline
Got Shafted
Has he tried pulling the inspection cover for the trans and see if the flexplate moves but the torque converter does not? The flexplate must be spinning for the cps to trigger but could have sheared the torque converter bolts?
Old October 12th, 2021, 18:29
Definitely pull inspection cover and see in there, does transmission have fluid in it?
Do you want to get rid of it. I think your 8-10hrs from me. For a small fee ill dispose if it
Noise from drivetrain on take-off murfs66 Modified Tech Discussion 9 May 3rd, 2011 18:04
a lovely metal scraping noise.... Ben824 OEM Tech Discussion 13 February 5th, 2010 14:59
Drivetrain noise NEWYXJ OEM Tech Discussion 3 July 15th, 2009 21:26
Odd noise from drivetrain. bigdaddyjlove OEM Tech Discussion 4 February 19th, 2009 14:43
Drivetrain Noise I need help squirrel80 Modified Tech Discussion 7 September 29th, 2008 18:36
