Old October 8th, 2021, 19:22
Black1990jeep Black1990jeep is offline
Rock Rail Instal, Position and to weld or bolt the legs?
I got a lifted wide tired XJ, 33x 12.5 inch tires that stick past the stock flares by 2 or 3 inches. I have just added weld in frame stiffener in the center. Now I am adding a rock rail that I got.
1.. For the Rock Rail Position, since my tires stick out further than stock, I am thinking to extend the rock rail legs so the rail sticks out further than for a regular narrow tired set up would be. My reasoning is that the further out the rail sticks, the more protection to the body it provides. However a limiting factor is that eventually if the rails stick out as the widest thing on your jeep, they may limit where you can go off road do to narrow trails, and tight spots between boulders or trees. However so long as I keep the rails within the width of my wide tires, I am not losing any ability for narrow trails as my tires are still the limiting factor. Thus I am thinking of mounting the rails out about an inch or two extra each side.
Is this a dumb idea? Any draw backs to having wider rockrails considers I got wider tires anyway?
2. I can weld the legs of the rails to my frame (Frame has stiffener) or bolt them. any down sides to welding? Has anyone had to remove their rockrail for anything? If I never have to remove it, welding makes sense, as I got welder in hand, but I can drill and tap if it makes sense to have the rail be easily removable, say for replacement if it get bashed.
Whats the pros and cons of weld and bolting of the rail legs to the frame?
What say you all?
Old October 9th, 2021, 06:49
Anak's Avatar
Anak Anak is offline
Stranger
Re: Rock Rail Instal, Position and to weld or bolt the legs?
I wouldn't go especially wide. That will only make it harder to get around obstacles. Often tires can climb an obstacle. I don't see how extra wide rails would be more of a benefit than a hindrance.
Rails may need to be removed in order to remove the front fender. Front fenders may need to be removed to fix your weak door hinges. That is the one example I have seen on someone's XJ.
I installed my rails by welding mounts to the plated frame. The mounts are square steel tubing, with one piece that slides inside another (comparable to a receiver hitch). In theory I should be able to remove them if I ever need to, but I am sure it will take a BFH to do the job.
Old October 9th, 2021, 08:00
Evan03 Evan03 is online now
2x8 welded a lot. 2" below the doors cut out.
They get used a lot dragging the xj through rocks trees and willows one of best mods that ive done.
Can use sliders to pivot around trees that i cant really steer around 8" is just wide enough to keep most trees out of the body sides.
So far the sliders havent gotten in the way of working on anything else
2x4 looks kinda cool with tube added
Old October 13th, 2021, 16:07
srb531 srb531 is offline
my sliders take a beating , they are bolted & welded on. just bolted would have never held them on.
JCR stage 2 sliders......bolt them or weld them? davidson99XJ Modified Tech Discussion 9 February 29th, 2012 18:12
D-300 shift rail position ??'s 043500 Modified Tech Discussion 0 July 24th, 2011 13:09
Rock Sliders; Weld or Bolt On? Maltese Chief Modified Tech Discussion 7 November 5th, 2009 08:11
Weld it on or bolt it on??? gill41083 Modified Tech Discussion 8 August 24th, 2008 12:29
Weld RK CA mounts instead of bolt SnagglePuss Modified Tech Discussion 6 January 16th, 2008 18:23
