Old July 9th, 2008, 11:07
BRIANHO13's Avatar
BRIANHO13 BRIANHO13 is offline
<- Yum Chocolate
Engine smokes
It only does it when driving down hill. Greyish smoke its a 98. Any ideas?
Old July 9th, 2008, 11:09
92DripCherokee's Avatar
92DripCherokee 92DripCherokee is offline
Re: Engine smokes
assuming you mean smoke from under the jeep, sounds like a rear main seal leak hitting the front pipe where it crosses the transmission bell housing.
Old July 9th, 2008, 11:16
BRIANHO13's Avatar
<- Yum Chocolate
Re: Engine smokes
Nope, comes out the exhaust, there is no oil leaking on the ground.
Also, my exhaust runs down the drivers side of the heep.
Old July 9th, 2008, 11:19
Re: Engine smokes
high engine vacuum can suck oil past worn rings and valve guides, right into the combustion chamber.
is it smoking the worst when you coast downhill?
Old July 9th, 2008, 11:20
BRIANHO13's Avatar
<- Yum Chocolate
Re: Engine smokes
Under compression braking.
I take that back it could also be doing it when accelerating down hill.
Old July 9th, 2008, 11:25
UNCC_99XJ's Avatar
UNCC_99XJ UNCC_99XJ is offline
Twisted Up
Re: Engine smokes
Mine does that if i've been sitting in traffic for a while and it gets good and hot......i'll get around to fixing it some day...
-Timbo -
-'99 Sport, RE 4.5" and a few other things
-'13 Performance Blue Ford Focus ST. DD & Race Car.
-'17 Ruby Red F150 Lariat. Tow rig and occasional DD
Old July 9th, 2008, 11:33
Re: Engine smokes
if you're burning like 1 quart a week, the old-time solution is thicker viscosity oil.
try 50 weight, its summer anyhow.
I tried this on my first engine, it helped a little.
Does lower your gas mileage slightly.
Old July 9th, 2008, 13:10
BRIANHO13's Avatar
<- Yum Chocolate
Re: Engine smokes
She's a trailer queen, I did change the oil and add a quart of lucas stabilizer. I think it did help a little.
Just wondering if anyone has seen this before.
Old July 9th, 2008, 14:07
old_man's Avatar
old_man old_man is offline
Re: Engine smokes
Smoke at high vacuum such as at an idle when hot means bad valve guides/seals. It is even worse going down hill under compression braking.
If it smokes under load, that means shot rings.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old July 10th, 2008, 09:32
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
Re: Engine smokes
How many miles on this engine? If it were mine, I'd perform a compression test and or leakdown (even better). I agree with old man here....
Old July 10th, 2008, 10:51
BRIANHO13's Avatar
<- Yum Chocolate
Re: Engine smokes
It's only got abou 90k on it.
I probably don't start it enough.
Starting to sound to me like I need to do a stroker.........
Old July 10th, 2008, 13:02
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
Re: Engine smokes
Maybe regear those 60's! LOL! I never even noticed it!
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
engine swap: 96 4.0 auto engine where 92 4.0 manual tranny engine is cjben OEM Tech Discussion 4 January 21st, 2010 19:52
Smokes after sitting... QRMTVI OEM Tech Discussion 7 July 10th, 2007 19:53
OBDII Engine Code Reader - Check Engine Light Diagnostic - NEW BigTP2 For Sale: Private Party Only. XJ ITEMS ONLY 1 December 19th, 2006 13:00
'98 4.0 engine smokes on hard acceleration lawlopez OEM Tech Discussion 12 October 22nd, 2006 22:31
'02 Mustang GT Smokes Occasionally, Dealer Says BrianB Tow Rigs and Trailers 4 October 20th, 2005 08:19
