Old March 6th, 2008, 20:00
MadPikAvenger's Avatar
MadPikAvenger MadPikAvenger is offline
2001 Spark Plug question
I searched around on spark plugs and was pretty settled on the Champion Truck Plugs. Then I read a post about Chrysler switching to the NGK plugs for later models. I have an 01 and was wondering if there was a reason for choosing one brand over the other. Thanks.
Old March 6th, 2008, 20:27
XJRubicon's Avatar
XJRubicon XJRubicon is offline
Re: 2001 Spark Plug question
NGK.
They are higher quality than any champion.
Champion would run 5 mins and foul out in my dirtbike.
Put in a NGK, lasted years.
Champion is for lawnmowers!
Autolight is also a decent plug but I will always run NGK's
Old March 6th, 2008, 20:38
4xBob 4xBob is offline
I've been running NGK plugs in the 2001 for about 1.5 years now- flawless so far. They also work exactly as they should in my 1990.
Old March 6th, 2008, 20:45
Alright...Thanks for the quick response...anything else i should look at while I'm changing the plugs?
Old March 6th, 2008, 20:47
XJRubicon's Avatar
Cap and rotor of course!
They go bad every few months for us. We wheel with a lot of moisture though but give it a look!
Old March 6th, 2008, 21:04
2000+s use a coil rail so there is no cap and rotor... Thanks though
Old March 6th, 2008, 21:12
XJRubicon's Avatar
Doh! i forgot about that.... you should be good to go then!
XJR
Old March 6th, 2008, 22:30
Alrighty...Thanks all
Old March 6th, 2008, 22:31
LR_2000_XJ's Avatar
LR_2000_XJ LR_2000_XJ is offline
A little anti-seize on the spark plug threads to guarantee an easy change next time.
Old March 7th, 2008, 10:52
EMSJEEP's Avatar
EMSJEEP EMSJEEP is offline
Just to clarify, what exactly is the stock plug for a 2001? Part #?
Old March 7th, 2008, 11:00
jeepman121's Avatar
jeepman121 jeepman121 is offline
[quote=XJRubicon]NGK.
actually champions were specifically designed to run in the 4.0. I think the engineers at Jeep would konw a little more than you about this, thats why we can get 300,000 miles + out of the 4.0 with 99 cent copper plugs. As for the later models...I've never heard they switched.
Old March 7th, 2008, 14:34
Stock plug for the 2001 is the NGK V-Power..part# ZFR-5N Just picked them up from the dealer. They did switch over from the champions for later models. The parts guy I deal with has worked there since before I was born.
Old March 7th, 2008, 14:43
XJRubicon's Avatar
[QUOTE=jeepman121]
Originally Posted by XJRubicon
NGK.
I would LOVE to see a 300k mile champion. I don't believe that possible.
Maybe they did design the champion to work with the 4.0, I would STILL never run them.
I have NEVER had a set last more then 10,000 miles. The NGK's that are in my truck have been in there since 03' and STILL it runs like a dream.
I bet they need to be replaced, but they are still running strong!
XJR
Old March 7th, 2008, 16:05
BillBraski BillBraski is offline
I don't think he said 300k on a set of plugs, he said 300k on a motor. Even the best, most over priced plugs can't go that long. My Oldsmobile Aurora northstar engine has 130,000 miles on it, and I just changed the stock platinum plugs last month, they looked good other than the larger gap from deterioration. I've use Accel and Champion plugs in my 4.0 XJ, both are good.
Old March 7th, 2008, 17:44
Hellbent's Avatar
Hellbent Hellbent is offline
i've mostly run ngk v-power's in my jeeps, although i've had pretty good results with regular old bosch super's as well.
Quick Spark Plug Question Davesxj OEM Tech Discussion 23 January 11th, 2008 15:06
No spark plug gap? hudsxj OEM Tech Discussion 22 November 27th, 2006 12:04
easy spark plug question . . . maybe 93RugbyXJ OEM Tech Discussion 5 October 18th, 2006 15:37
Spark Plug Gap Question MachineMan OEM Tech Discussion 6 March 24th, 2005 13:07
Quick Spark Plug Question Karlm OEM Tech Discussion 11 July 22nd, 2003 07:30
