wheelin99s
- Hudson, Wisconsin
I just noticed that when I grab my harmonic balancer and rotate it by hand I have a little bit of free play turning it either direction before it hits and then you can feel compression.
Is this normal? I does it wether I turn the balancer itself or the balancer bolt. You can hear it kind of 'clunk' when it hits and then u go the other direction and 'clunk' before the compression. Motor runs great, good oil pressure, although it does have a very slight knock from the oil pan or bell housing area maybe..
