Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > Past NAXJA Events > PAST NAXJA EVENTS > 2003 Winterfest, Attica Indiana
2003 Winterfest, Attica Indiana Winterfest 2003 at Attica Indiana. Feb 8th. Fourth Annual Event Forum
Past Event: Closed to new posts.
Old October 23rd, 2002, 09:59
4ward's Avatar
4ward 4ward is offline
Whatchya gotta get done
Just wondering what mods and non mods we all have to do. I've got front locker probs and a hub to replace. I need to flip my rear springs around also. Other than that I think I'm good to go. I doubt I'll get any wheelin' in before then so I shouldn't break anything else
Sean
  #2
Old October 23rd, 2002, 19:28
Scott Mac's Avatar
Scott Mac Scott Mac is offline
NAXJA Member #10
Adjust my steering box, adjust my caster so I can steer and drive with the front shaft installed, need to do some semi major fendor triming and I need to drop my newly installed tank and fix the fuel level sending unit.
I may pull the rest of my interior and Hurculine the floor but I'm thinking that may wait till spring when it gets warm again.
Oh ya and I definatly need to get my CD changer back in there so I've got some tunes to listen to. If not I'll go crazy if I have to listen to Beezil all day long on the CB.
  #3
Old October 23rd, 2002, 23:55
trailblazer93xj trailblazer93xj is offline
NAXJA Member #144
Why flip the rear springs around?
What effect would that do?
  #4
Old October 24th, 2002, 10:43
Fore Wheeler's Avatar
Fore Wheeler Fore Wheeler is offline
MWC President
I really want to get my d44 and 9" in and big tires like Sean and Matt, ya know, so I can feel included in the bigger the better club.
  #5
Old October 25th, 2002, 14:12
Guest
Posts: n/a
Fix slow pass side pwr window.
Touch up rock chips on the bottom of rocker guards.
Shampoo carpet.
Track down slight vibe at 80 mph.
Wax shocks.
Polish my knob. (it's a manual).
Replace cracked driver side cup holder.
Whew, lots to do, better get Jeeves off the Bently and on to the XJ.
  #6
Old October 26th, 2002, 10:20
Guest
Posts: n/a
Re: Why flip the rear springs around?
[quote:e478e332ae="trailblazer93xj"]What effect would that do?[/quote:e478e332ae]
Would what do?
  #7
Old October 26th, 2002, 10:23
Scott Mac's Avatar
NAXJA Member #10
[quote:9d7b0f3155="Anonymous"][quote:9d7b0f3155="trailblazer93xj"]What effect would that do?[/quote:9d7b0f3155]
Would what do?[/quote:9d7b0f3155]
Sorry, That was me, I forgot to log in after I dumped my cookies.
  #8
Old October 26th, 2002, 10:31
4ward's Avatar
I was thinkin' the same thing. Those Missouri types- I don't know if we should let them come out and play with us.
Sean
  #9
Old October 30th, 2002, 16:51
macgyvr's Avatar
macgyvr macgyvr is offline
NAXJA Member #120
60s.............
There is a possibility that I'll have 60s in front and rear...if not that's the first project after winterfest...
a cage also tops the priority list as well...
mac 'big projects on the table' gyvr
MWC President / President
It's always a good time to join or renew your membership!
My idea of a perfect vacation is a road trip through beautiful country. To make it really fun, all that's needed is a modified vehicle, a few close friends, and some serious off-roading. Cole Quinnell - Editor, 4WOR, Dec 99
  #10
Old October 30th, 2002, 18:20
MRHinkley
Guest
Posts: n/a
Sean,
Are you sure that is all you have to do.
Hiem?
Welding bracket for traction bar?
Make it pretty?
mark
orgs mfg
  #11
Old October 31st, 2002, 00:29
Goatman's Avatar
Goatman Goatman is offline
[quote:866cf64b7f="MRHinkley"]Sean,
Hiem?
Make it pretty?[/quote:866cf64b7f]
Mark, he needs friends like you to remind him, or else he'll just work on unimportant things like the heater!!
BTW, what do you mean "make it pretty"? Sean's rig is BEAUTIFUL!
Richard G
  #12
Old October 31st, 2002, 07:02
4ward's Avatar
I'm probably not going to worry about the traction bar, and I'm definately not doing anything about the heim. I'm redesigning the front suspension this winter and don't want to waste money on upgrading something that I'm going to throw away. And like Goat said, it's [b:7d42d7b96e]BEAUTIFUL[/b:7d42d7b96e].
Sean
  #13
Old October 31st, 2002, 20:08
NAXJA Member #144
Re: Whatchya gotta get done
[quote:f03ebc5f06="OneTonXJ"]I need to flip my rear springs around also.[/quote:f03ebc5f06]
Thats what I was Asking about. :shock: What effect does that have?
  #14
Old November 3rd, 2002, 12:47
4ward's Avatar
Wheelbase modification. Go get your tape measure out and check your center pin to spring eye distances. I was going to do it, but RE doesn't use the stock offset and it'll be too much work and I might need a new driveshaft.
Sean
  #15
Old December 3rd, 2002, 07:19
TRL WGN 1's Avatar
TRL WGN 1 TRL WGN 1 is offline
let's see,
install 8.8 (got the perches ground off last night, so we are moving along)
regear front to 4.10 to match 8.8
put the mini spool in the 8.8
cut out rockers and replace with 2x6 tubing (picking that up today)
pull t-case again, and fix front seal leak, and see if I can figure out the clicking noise inside. Have had it apart, and can't find anything wrong. Still works fine, so I may say screw it!
Got the other wheels mounted up this weekend.
Need to intall a front locker once the money comes in (stupid Christmas)
How necessary is an engine tranny skid? Don't have one, and wondering if it is necessary for Attica? We don't have rocks in Central IL.
Was going to add 2" of lift, but don't have the funding right now.
Oh, and try and slow down some of the oil leaks.
Good thing I am trailering this thing!
Rate This Thread:
NEED HELP ASAP Jeep is in pieces and i gotta go to work tomorrow 91XJ Modified Tech Discussion 28 December 14th, 2003 20:15
Gotta love redneck justice woody Non-Tech / Off Topic 12 September 3rd, 2003 22:30
Wanted - D30 XJ/MJ gotta have 3:55 gears LAWNMAN323 Wanted: Private Party Only 3 August 2nd, 2003 22:19
Gotta top!! Rev Den Modified Tech Discussion 5 July 26th, 2003 01:08
Gotta tell someone GI-John Non-Tech / Off Topic 17 July 22nd, 2003 21:42
