Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
rebuilt rear wheel wells
We are working on a buddies '90 2 door XJ. I got this idea from another thread here on naxja. This one: http://www.naxja.org/forum/showthrea...e&pagenumber=1
We started to do the same cutting, but got looking at the inner wheel wells and are thinking about making new ones much longer and taller. We are thinking about continuing the front of the wheel well curve up to the body seam; about 4" below window. Then follow that seam straight back, and copy the front curve back down to just miss the taillight. The goal is to keep it low and fit 38s with 5.5" springs flipped for 6" more wheelbase. It will have an interior cage and fuel cell also. Is there any pics floating out there of any rebuilt inner wheel wells, just to envision the space they take up. |
#2
Your going to have to make your own wells if you decide to go with the body line cut. I think you'll find that when you get that high on the cut it looks wierd.. I go a few inches higher then the actual wheel well and stay out of the body line. Use 14ga sheet metal on the inner wheel wells. It's alot eaiser to work with when making the large curved bends. There are more pictures added to the folder or Creepers on my site.. Creepers
Have fun ![]() |
#3
I'm gettin ready to do the same thing. Follow the door up to right below the body seam and then go straight back. But I think I'm gonna go all the way to the tail lights. Remove the lights all together and put leds in my rear hatch. I'll build my bumper to go up beside the hatch so it can't be damaged. This way I am acutaly narrowing the rear end of the vehicle. If this makes any scene. I've got a cad drawing of it I'll post later.
#4
Well, we decided to go with the factory look approach instead of fully tubing it. It is pretty much the same thing as AZXJ did, but I'll post a few pics anyway.
#6
outside
#7
filler
#8
almost done
![]() I have to finish welding and get the driver's side in tonight. That's all. |
#9
looks pretty damn good to me...nice work.
#10
looks good! I hope you have a good traction bar with running the long side of those springs forward.
#11
I'm planning on taking the rear from the top of the wheel well off straight back. Lights are going to look like Bart Jacobs XYJ.
#12
I threw together these for mine. I'm not completely thru with the design. But this is it for now. I'm gonna biuld the bumper I out on here till I gut the rear. Just collecting parts now. Whatca think?
Thread Tools | |
Display Modes | |
Buick 3800 in a rear wheel drive??? | daytripper | Tow Rigs and Trailers | 20 | March 14th, 2008 18:14 |
Rear axle seal? | XJHOX | Modified Tech Discussion | 8 | June 23rd, 2005 15:30 |
REar CV driveshaft | BigBlk XJ | Wanted: Private Party Only | 3 | October 26th, 2003 11:25 |
Rear Wheel Studs | REDDOGG.XJ | Modified Tech Discussion | 0 | August 30th, 2003 13:31 |
Rear Wheel Cylinder | Manuel | OEM Tech Discussion | 9 | April 6th, 2003 19:07 |
