Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
#31
Re: Rolls in gear
No, it would cause you to burn up/seize the case but not what your describing.
#32
Re: Rolls in gear
For those of you saying it's something with the parking pawl, do this: Go put your transfer case in neutral. Start the jeep, put it in drive, then put it in park. You'll hear the noise he's talking about.
What you have here, JMO, is an issue inside the transfer case. On a wild guess, I'd say the shift forks weren't aligned properly and it's just staying in neutral. (Transfer case neutral, that is). You need to take the case back off and crack it open again. Diagnosis without the vehicle in front of you is difficult, but this is a no-brainer. The t-case must come back off, and you need to find out why it's staying in neutral. |
#33
Re: Rolls in gear
Thank you Agreen! I am pulling the transfer case off today after work. I truly appreciate everyone’s help and will let you know what is going on as soon as I know. I truly appreciate the XJ Family willing to help me.
#34
Re: Rolls in gear
So guys may I start off with apologizing. I’m sorry for not simply checking my work prior to asking you all for help and occupying your time. I am eight months into recovering from being hit on the freeway while riding my motorcycle and working on my Jeep was me trying to get back into motion. I am realizing I am struggling with my memory. The issue was simply the shift for in the wrong location. I pulled the transfer case out today. I will tear it apart tomorrow and put it back together right this time. Hopefully... once again I am sorry and I truly appreciate everyone of you who took the time to chime in. Thank you.
#35
Re: Rolls in gear
Very nice! I'm glad you found the issue. You can check the operation before reinstalling the transfer case too. Spin the input shaft and check the output shafts as you shift through the ranges. And as was mentioned before, you also need to check the shift linkage for the proper adjustment once it's all put back together.
#36
Re: Rolls in gear
Pulled it all apart and realized I installed the synchro sleeve backwards. Easy fix if anyone ever encounters these symptoms. Thank you all for your help.
#37
Re: Rolls in gear
Bad news. I flipped the synchro sleeve and installed the transfer case and still nothing.
#38
Re: Rolls in gear
Could it have anything to do with the original transfer case being vacuum and the new one not being vacuum? Is it possible that the computer is receiving the command from the vacuum?
#39
Re: Rolls in gear
Personally, my only experience was to replace the out put shaft with a SYE shaft in the NP-231. According to the manual I have, that TC not complicated at all. Some others with AWD and/or vacuum operated could be a bit more finicky to repair, (I think). You may be able to get more help if the group know exactly what you are working with.
Patrick ![]() 1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries. |
#40
Re: Rolls in gear
Both are np231
#41
Re: Rolls in gear
Thank you Patrick
#42
Re: Rolls in gear
I came across a 1991 Cherokee that I pulled the transmission and transfer case out of. I put the sye in the 1991 transfer case and installed that in my 1990 Jeep Cherokee. The 1990 was vacuum and the 1991 was not.
#43
Re: Rolls in gear
That sounds like your problem, the '90 is 21 spline and the '91 should be a 23 spline!
https://www.novak-adapt.com/knowledg...g-input-gears/ |
#44
Re: Rolls in gear
That was kind of important info to leave out! At this point you could either swap over the SYE or look at swapping out the input gear but you will have to be aware of the gear cut and the length.
#45
Re: Rolls in gear
Thank you sir you are 100% correct. I went and measured the transmission and transfer case I have out. Thank you so much. The next question is can I simply just swap the input gear? Or do I just put the sye in the 1990 transfer case?
Thread Tools | |
Display Modes | |
Nss replaced now it rolls in park | willsmysticcobra | OEM Tech Discussion | 10 | November 5th, 2013 00:46 |
Were you at the rolls(Butcher Jones)....... | RCP Phx | Arizona Chapter | 1 | September 15th, 2009 07:37 |
jeep rolls when in park | 85xjproject | OEM Tech Discussion | 7 | May 4th, 2008 07:47 |
The Short Bus Rolls tonight!! | Sniggs | Non-Tech / Off Topic | 0 | December 7th, 2006 10:35 |
Cherokee Rolls 800ft!!!!!!!!!!!!!! | jammerjamesharmon | Non-Tech / Off Topic | 19 | August 18th, 2004 17:07 |
