Old June 22nd, 2020, 13:17
JMO1990renix JMO1990renix is offline
Re: Rolls in gear
I did test prior to installation. I will take the drive shaft off after work and see if it moves in park. One thing i left out was I had the head surfaced and installed it at the same time. Initially I was leaning towards electrical. Now I’m leaning towards trans oil/filter
Old June 22nd, 2020, 16:12
Re: Rolls in gear
I tested it prior to install. But when I get home I am going to pull the rear driveshaft and see if it spins in park.
Old June 22nd, 2020, 18:20
Re: Rolls in gear
I can push the Jeep back and forth in park. Does that mean there is No need to disconnect the drive shaft? Will that not give you the information you need to make a determination?
Old June 22nd, 2020, 18:26
Hypoid's Avatar
Hypoid Hypoid is offline
Re: Rolls in gear
How far will it roll back and forth?
I can put my Jeep in park, push the tire with my big, fat, foot, and get the thing to rock back and forth. That is how I inspect the U-Joints.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old June 22nd, 2020, 19:46
RCP Phx RCP Phx is offline
Re: Rolls in gear
From everything you've said so far, I would say you have a bad "parking pawl".
Old June 22nd, 2020, 20:23
Re: Rolls in gear
I can push it 20 feet forward and backwards in park, drive, 3rd and 1-2. It doesn’t just rock back and forth. Would a Brocken parking pawl affect anything besides park? Thank you again for taking the time to give your input.
Old June 22nd, 2020, 21:01
Re: Rolls in gear
Yes you definitely have something bad in your parking system. Depending on what broke would determine how it would effect the other gears.
Old June 22nd, 2020, 23:11
Hypoid's Avatar
Re: Rolls in gear
Originally Posted by JMO1990renix View Post
I can push it 20 feet forward and backwards in park, drive, 3rd and 1-2. It doesnít just rock back and forth. Would a Brocken parking pawl affect anything besides park? Thank you again for taking the time to give your input.
There is something wrong, somewhere... Does it do the same thing in 4-Hi/Lo?
Old June 23rd, 2020, 06:38
Re: Rolls in gear
It does it in all gears in the transmission and all gears on the transfer case.
Old June 23rd, 2020, 06:40
Re: Rolls in gear
I don’t know if this changes anything but I used a transfer case out of a 1991 Jeep Cherokee xj and installed the sye kit in that one. Then installed it in my Jeep.
Old June 23rd, 2020, 07:32
Re: Rolls in gear
That won't fix your trans!!!!!!!!!!
Old June 23rd, 2020, 08:40
Destroyer Destroyer is offline
Re: Rolls in gear
I donít know if this changes anything but I used a transfer case out of a 1991 Jeep Cherokee xj and installed the sye kit in that one. Then installed it in my Jeep.
Do you still have your original tcase? If so swap it back in temporarily and I bet the issue goes away. The issue is not in the trans. You did not damage the park pawl or anything else by running it slightly low on fluid for a bit. The only thing I cam think of other than it being an issue internal to the tcase is that the input on the new case is too short to engage the tail shaft on the trans. This would make it seem like the shift selector on the tcase works but still act as if it's in neutral.
Old June 23rd, 2020, 21:06
Re: Rolls in gear
I will try that this weekend. Would that mean the sye kit I put in that transfer case wasn’t for the aw4 transmission? I bought it off a seller on offer up.
Old June 23rd, 2020, 21:24
Re: Rolls in gear
I read something about different spline counts for different years. The transfer case with the new retailer sye slide in no problem.
Old June 24th, 2020, 06:45
Re: Rolls in gear
I read something last night about lining up the tail shaft notches and the oil pump. I don’t recall any of this. Could this potentially be an issues?
Nss replaced now it rolls in park willsmysticcobra OEM Tech Discussion 10 November 5th, 2013 00:46
Were you at the rolls(Butcher Jones)....... RCP Phx Arizona Chapter 1 September 15th, 2009 07:37
jeep rolls when in park 85xjproject OEM Tech Discussion 7 May 4th, 2008 07:47
The Short Bus Rolls tonight!! Sniggs Non-Tech / Off Topic 0 December 7th, 2006 10:35
Cherokee Rolls 800ft!!!!!!!!!!!!!! jammerjamesharmon Non-Tech / Off Topic 19 August 18th, 2004 17:07
