Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
#91
Re: Bilstein shocks... whatchya gonna runnin??
Nope! I have been rebuilding the rear end piece by piece and delaying the inevitable...
You are running out of compression because those shocks are to long... finding a shorter shock that still has the down travel you want will put you in my boat... only, with my extra lift it should be easier! 16” compressed.... 32” extended... why is that so hard to come by?
97’ XJ lift lockers 35s mid arms 9"/hp30 trussed warn hubs wj brakes 1ton OTK 4.56s etc work in progress.. 93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old ![]() |
#92
I have 4" of compression that is plenty. But about the ske down travel.
16" is the 11" 5125 compressed 16" is 8" fox comressed Somehow 5125 overal is shorter for stroke length My compressed 4" virtually stay the same but I gain 2" down hmm 2" doesn't even sound like its worth it. Or I get 12" fox foa king rework mounts so I have 6" of shadt showing at ride height or 4" and have 6" down wicj just abut works out to the same as bolting 11" 5125 in my current brckets. |
#93
This is at ride height.
Plenty of compression actually perfect tire touches my fender ![]() Sent from my SM-G960U using Tapatalk |
#94
Holy Moly.. just read all 7 pages of this thread. Did you guys ever come up with a solution? Most of what I read about downtravel, etc. is new to me. But I'm not in the same boat as you and not super-fine tuning squish & droop..
I'm just wondering which Fox 2.0 to get from Accutune.. they have a couple options for ranges of lift. I'm calling them this afternoon to try and pin it down. All this ties in with the threads you guys have been dealing with me on.. SRB, drop shackles, new springs, CAD.. yada, yada.
I'm a 'Do-it-Twice' kinda guy. 1999 XJ Sport 4.0L Black |
#95
Which lower shock mounts? The rear lower mounts were moved up on recommendation of DPG with OME kit.
#97
I'm thinking it's moot for me. Contacted MetalCloak re shocks with their 4.5" progressive springs. Turns out they use OME 60052L on the front with their springs and that's what I already have on the XJ.
60053 (no L) on the rear so looking to see if the 'L' is a real thing for the rears.
#98
I'd definitely do race series with ladies adjuster. Wouldn't go shorter than 10"
Cycle it with coils removed to get best shock lenth. Rework upper and lowers ad needed |
#99
Remote reservoir has nothing to do with heat dissipation It's about packaging travel You can get 7100's with custom valving, and you can also get Fox 2.0's with custom valving - both from Offroadwarehouse |
#100
Didn't see much if any packaging difference between res or not across the board of manufacturers.
Vakved 7100s would also be nice Sent from my SM-G960U using Tapatalk |
Thread Tools | |
Display Modes | |
Bilstein Shocks | Serious Offroad | Vendor Advertisements | 6 | June 6th, 2020 20:31 |
Help please which Bilstein shocks?? | spdyracer | Modified Tech Discussion | 7 | January 21st, 2012 19:02 |
Whatchya' doin'? | Ryno XJ | SoCal Chapter | 15 | May 8th, 2009 08:25 |
what kinda shocks u guys runnin? | smokeeaterXJ | Modified Tech Discussion | 8 | May 5th, 2006 23:40 |
Whatchya gotta get done | 4ward | 2003 Winterfest, Attica Indiana | 34 | February 2nd, 2003 21:04 |
