biscuitboy87
- CA/OR
2000 xj auto bone stock.
never had any problems (except loose filler stop) until this morning.
last night ran fine, parked it, woke up this AM for work and on first crank of the key it caughed and died. tried the key again and it started and ran rough (like only a few cylinders wre firing?) and started throwing codes (flashing engine light). shut it off and started it again...started fine (check eng. light still on but not flashing). during the second startup the battery seemed to be drained, but third startup it fired perfectly. its not too cold here in cali, but temps are starting to fall a bit (50 deg this AM)
I did a search and found some similar but they specified hot temps and fuel issues, and the rough idle symptom seemed to right itself, but in my situation it kept running rough 'til i shut down and retarted.
As always i am greatful to this web site for its content, and have had great help in the past. thank you to all.
Nim
Nim
