XJ LM7 5.3 swap
indian
I decided to start this thread because it can help someone. I got a lot of inspiration from other's threads like from racer32, John D, PhotoJared, Frank Z, Jeff 98XJ WI, etc.. I would like to thank all the XJ LS swapers. Excuse my english.
My XJ is a 2001 sport. I put a M62 supercharger in it to get more power, but I was not very satisfied. Then I put a comp cam 232-4, piggyback ecu, wideband, headers but the results was poor for the effort. So I decided to go the LS route because I knew the engine from Corvette and I very like the V8 sound and torque production.
Now I am at the middle of the swap. (I hope).
This swap began in Feb 2017 when I got the package from ebay:
then I pulled the old engine out:
which one is better?
but when I took the old truck intake I got a bad feeling about the LM7 (156k miles) engine
and my frustration was bigger and bigger
the engine was full of carbon buildups
so I continued to the bottom end and without any surprise it was full of rust and carbon
the rod bearings destroyed
cleaning and rebuilding of the engine:
new exhaust valves
new valves seals
old springs, retainers cleaned
heads ready to instal
crank bearings left some marks on tha crankshaft
hope this will work
most engine parts ready
honing the cylinder
should be OK
assembling the bottom end
installing the oil temperature sensor for my VDO oil temp gauge
Jeep oil pressure sensor for the OEM jeep cluster
a little bit longer adapter for the Jeep coolant temp sensor
thanks Racer32 I bought the Camaro 99 headers
for the fuel delivery I decided to use the sending unit from the diesel XJ (has inlet and outlet without regulator) and combined it with the 4.0 fuel pump. regulator is GM on the rails
I bought the russel fuel lines and adapters:
lowered the truck fuel rail crossover line
some clearance issues with throttle body and water pump outlet. slighty bended and looks OK
test fitting of the intake hose with MAF
other VDO oil temp sensor for the 4L60e
engine and tranny together again
swapping the input gear and planetery gear from the NV246 to the NV231
for the VSS I reused the 37 teeth ring from NV246 and placed it into the NV231. I will then reprogram the ECU to count the 37 teeth (stock VSS is 40 teeth ring)
the GM VSS sensor adapted into the NV231
many thanks Racer32 for the adapter ring specs
Wow Peter looks great so far! Glad the adapter worked for you. Looking forward to more :)
end of May 2017 - LM7 first (hopefully last) install
transmission mount
engine mounts - I welded some universal LS mounts to the stock Jeep mounts
manifold to mount clearance - passanger side
manifold to mount clearance - driver side
I hope you replaced the knock sensors while you have the engine apart.
Apologies if I missed that.
modified jeep throttle cable bracket:
very custom modified jeep transmission cable bracket :looney:
I only grind the last detent and it shifts through all the gear without any problems
transfer case shifter linkage (it will be welded and painted)
Nice looking good!
I checked the clearance between oil pan and front axle and I think I am very tight. the engine is too low. At full drop the steering stabilizer bolt hits the oil pan:
I made bigger bumpstops and cut the bolt:
oil pan to axle very tight at full drop:
other option is to buy a flat steel oil pan. or any other suggestions?
and with the parts to EU it is not a big problem except I have to wait longer and pay a import fees. yesterday I got a very nice package:
IIRC there are a couple vendors over at the pirate4x4 forums that make aftermarket 'shallow' pans with added baffles.
Pacific fab comes to mind.
I like this ICT accessory bracket kit, because of short belt, no idler, no tensioner only manual turnbuckle tensioner, very nice product, easy instal:
tight clearence but OK:
one thing I have to do is cut the steering pump spacer about 15 mm (0.59") because the old Jeep pump has other distance of the pulley than camaro pump:
That doesn't seem to be much engagement on the waterpump or crank pulleys.
