Old May 31st, 2022, 20:30
lawsoncl lawsoncl is offline
Re: 96 XJ stumbles then shuts off when warmed up. P0171
It wouldn't hurt to try measuring the voltage at the connector to the fuel pump before you pull it. There is a chance it's a corroded connection or wiring issue.
Old May 31st, 2022, 20:31
If you have a regulator on the fuel rail, you'll also have a return line to the tank.
Old June 1st, 2022, 05:56
Anak's Avatar
Anak Anak is offline
Stranger
He doesn't.
See post #58.
P0132 P0171 Shaller13 OEM Tech Discussion 4 February 27th, 2022 08:34
P0171 Driving me Insane!!! XJSteven OEM Tech Discussion 234 October 23rd, 2011 21:49
P0171 O2 sensor diagnosics - '97 XJ SteveX82 OEM Tech Discussion 37 October 1st, 2011 17:58
97 XJ, P0171 Fred OEM Tech Discussion 1 August 2nd, 2011 16:01
P0171 help, which O2 sensor? zerogspacecow OEM Tech Discussion 6 April 29th, 2011 12:08
