Relocation brackets
Just ordered a set... thanks!
just curious, how long do these usually take to get to California?
Wow that was fast!! just got them.
Thanks!
Is it possible to install these, and gain no lift?
Running boomerangs now, would go with a shorter shackle obviously
You could get no lift if you went with the corect shackle angle and a shorter shackle.
I gained less than an inch lift from them, so I'm sure you could do it with no lift.
That said, installing these we went from abuot 8" rear end travel to closer to 12" rear end travel (and at that, we were limit strapping and could have gotten more).
This product gets an A+. Do not forget to check your pinion angle after installing them though.. :)
