Digital Torque Wrench - Holiday Special
Brownline
Chicago
I couldn't figure out how to edit our previous thread on our wrench, but I wanted to let everyone know that we are extending this special during the upcoming Holiday Season (until Dec. 25th). Our wrench makes a great gift - so don't miss out !!
The special is our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: NAXJA
You can see the torque wrench in action in the following video:
Please note that while we are happy to answer any questions you might have, the information might be in our previous thread.
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is until Dec. 25th, and is only for the lower 48 states.
We have gotten a number of requests lately, we we are going to re-activate the NAXJA code and keep it open for the time being. Thanks for the support.
BLMW
IIRC, they are in the process of making a lower cap. and higher cap. tq wrenches.
looks good... I'd prefer an American made one (hey, it keeps folks like me working and such, right?) but from the good folks over at the vw TDi forum report that you have a calibrating/service facility over in the Windy City. Better than nothing. Hmmm... I'd probably be interested in a set (ft lbs and in lbs). I'm sure I'll be kept up to date.
Inch-Pounds would be good. I'd consider buying one for gear setting (you need to track how much force it takes to turn the pinion, typically one uses a dial type torque wrench for this, a beam works in a pinch and a micrometer style will not work at all).
We have gotten a lot of feedback like yours. We are doing our best to get them out as quickly as possible.
BLMW
