need bump stop help....
Mr.OverKill
need bump stop help, i am installing a lift ect... and need to mount the rustys adjustable bump stops but the question is what thread and size bolt and length do i need to mount this thing????? i bought the stops only because i mounted a chevy 350 in my jeep and dont want to smack the crap out of it even with the lift and 33" tires ( better safe than sorry )
thanks for the help
Troy
call the local Jeep dealer and ask what the bolt size is....then go to the local hardware store and get an extended version of it. If the extended version of this bolt is too long, add small washers or something.
I do understand you in thinking that you will be using the stock thread hole...right? If you will be using the stock threads.....call the dealer for thread size.
Brian
