Firewall to engine grounding strip detached and corroded.
Would like to replace it.
Would a cable like this be a good idea?
Not sure of the bolt/stud sizes.
That would work, but something that a lot of people don't realize is that the factory used a braided strap instead of a fat round cable because a braided strap is flat and thin and thus has lower inductance than a fat round cable of equivalent cross section. That strap is only there to shunt RF interference to the chassis so that ignition noise from the right side of the motor doesn't get into all the sensitive EFI sensor signals on the left side of the motor, it doesn't handle cranking current. The heavy wire from the battery negative to the block or ignition coil mounting stud (depending on year) is the one that handles the heavy current loads from the starter motor and alternator.
That cable will probably work fine since it's much larger gauge than the strap, but a cheap braided grounding strap of the same size (or ideally the same thickness but wider than factory) will do fine too if you want to save a couple bucks.
