Old December 29th, 2014, 19:59
Lkwelch's Avatar
Lkwelch Lkwelch is offline
Question Rubicon Express sway bar links
Hello all,
I just installed a RE 3.5 inch super ride on an 89 XJ. The sway bar links that came in the kit required a spacer on the axle end and they didn't seem to line up properly when following the install directions. The drivers side went in as the instructions said but on the pax side I had to flip the spacer to make it line up. Just wondering if anyone has run into this before. Also it's the front sway bar.
Thanks
Old December 29th, 2014, 23:29
VAhasnoWAVES VAhasnoWAVES is offline
Re: Rubicon Express sway bar links
you got instructions with yours... must be nice. the extended sway bar links that came with a buddies 3.5" kit were far different than the quick discos RE gave me with my 4.5" kit 8 or 9 years ago... it took me a good while to piece together the links and hardware. mine made sense, his links seemed like they were cutting a bunch of corners.
anyways... before you put on the sway bar links, make sure the axle is properly centered and the track bar is installed. from there, double check that the sway bar itself is properly centered in its mounts. you should be able to push/pull it into position while twisting at the same time. a little grease may make it easier.
if it still doesnt line up, double check that the mounts on the axle arent bent.
and if it STILL doesnt line up... well, welcome to the RE club.
Old December 30th, 2014, 08:18
Lkwelch's Avatar
Thanks for the info VAhasnoWaves. I think that I will be just be joining the RE club.
The sway bar doesn't really have any wiggle room side to side on mine and the axle mounts looked straight. I moved the track bar by drilling a hole 3/4" towards the drivers side on the axle mount. And everything looks centered. I am getting the alignment done today so it may change some geometry afterwards.
Old December 30th, 2014, 08:55
Lkwelch's Avatar
Correction!
I guess after my test drive yesterday everything shifted into place. Just went outside to look at it and it was cocked the other direction. Flipped the spacer back to normal and viola it's good. Thanks for the help! All good info.
Rubicon Express Sway Bar disconnects (BRAND NEW) xdutyxj00 SEC For Sale / Wanted Forum 0 February 5th, 2012 22:13
Rubicon Express Sway Bar Relocation Brackets Mackie007 For Sale: Private Party Only. XJ ITEMS ONLY 0 September 16th, 2008 21:56
Rubicon Express RE1142 Sway Bar Quick Disconnects Capt. Nemo For Sale: Private Party Only. XJ ITEMS ONLY 2 March 5th, 2007 06:13
f/s. Rubicon express sway bar disco's outlander For Sale: Private Party Only. XJ ITEMS ONLY 0 October 1st, 2006 22:16
