Old June 24th, 2017, 16:18
DinoXJ DinoXJ is offline
2000 XJ Classic Right Rear Window Issue
Ladies and Gents, I've got a moderately inconvenient yet extremely annoying problem. The RR window will not go up or down by either the drivers or passengers switch.
This is not related to the window lock bypass issue that causes lack of control of the windows by the passengers. That was also an issue but did not give control of the window to either switch.
Here's what I've done so far troubleshooting wise:
1. Put RR window switch on LR window and LR window rolled down
2. Connected RR window motor to the LR window switch and the motor moved up and down with no noises or issues
3. Replaced driver main switch and all three other windows still have full control, nothing on RR window
4. Put voltmeter to wiring harness going into the switch and got power at the green/white (power for down) wire and got 12 volts when pressing switch down from the driver main switch, Did not get power at the gray/black (power for up) wire when pressing switch up at the driver main switch. I checked the LR for reference and both their wires got 12 volts where necessary
5. Checked wires in door boot and all were good
There isn't anything else I can think to do before chasing wires. Before tearing through my wiring harness I wanted to see if anyone had any suggestions, fixes, or at least a direction to head.
Can anyone help?
Old June 24th, 2017, 17:49
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Re: 2000 XJ Classic Right Rear Window Issue
Use a 12 volt power source and jumpers and test the motor itself
Old June 25th, 2017, 09:57
The motor works when it's switched up to the power supply on the other side. It goes up and down.
Old June 25th, 2017, 19:55
crossfamman crossfamman is offline
I would check your wires in the driver door as well you can have a split wire there also try a simple continuity test to make sure it is working in both directions sounds like only down is working on the switch
Power window issue 2000 4.0 Ahhlicks OEM Tech Discussion 0 February 27th, 2015 12:52
2000 xj Window Issue Trixie03 OEM Tech Discussion 13 April 22nd, 2013 10:22
2000 Xj classic 4x4 shifting issue seanjohn0226 OEM Tech Discussion 3 January 16th, 2013 17:19
2000 XJ Classic Rear Seat RSchurig356 MWC For Sale/Wanted Forum 1 June 12th, 2009 20:49
2000 classic rear end, pinion gear. flsurfer19 Modified Tech Discussion 5 June 29th, 2005 16:12
