Old June 25th, 2017, 12:29
cushdaddy cushdaddy is offline
Cooling issues
My phone won't let me search and my computer sux. It been about 80 here in Ohio and I have been getting hot. 1998 with 4.0 and auto trans. New radiator about 5 year's ago. I installed it, but the PO bought it. Blew the side off. I typically have sludge at my cap. I replaced the T-stat, the water pump and the fan clutch. It still went up to the electric fan kick on point. I don't know of stop leak was added at any point, but I flushed it and I am still running hotter than normal. What is the best way to flush and check the radiator? I have watched some videos, but, I've done all that. If the radiator is partially plugged, what is the best cleaner? Should I pull the radiator and lay it flat and let it soak?
Old June 25th, 2017, 14:10
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Cooling issues
I think it would be a better idea to install a fresh radiator. 5 years from low budget radiator is about all one should expect.
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Cooling issues agaribay8 OEM Tech Discussion 12 August 29th, 2014 05:42
cooling issues rockthrasherxj OEM Tech Discussion 8 January 20th, 2013 08:11
Cooling 4.3 issues Bubbalou Modified Tech Discussion 4 October 4th, 2010 11:46
Cooling issues zcoughlin OEM Tech Discussion 7 August 17th, 2010 23:01
Cooling issues Ranger187 OEM Tech Discussion 11 November 4th, 2005 14:11
