Old May 15th, 2019, 15:58
TRCM's Avatar
TRCM TRCM is offline
Weird noise - can't decide
Developed a noise today that sounds like a fan blade hitting something, but it is coming from the engine - trans mating area......didn't hear a knock with the stethoscope, and it seems to only show up when the trans is in gear.
Any ideas ?? This is my daily driver.
Maybe a loose flexplate bolt ??
It is a card in the spokes kind of noise (for those old enough to know about playing cards in your bike spokes)
Old May 15th, 2019, 19:19
Heavyopp Heavyopp is offline
Re: Weird noise - can't decide
From what you describe it sure sounds like a flexplate to torque converter bolt backing out — better have a look before it causes real problems
Old May 16th, 2019, 12:36
JRWinnett JRWinnett is offline
Pop the flexplate cover off, and take a look. Check for any loose flexplate bolts, or pry on the flexplate to see if it is cracked.
Old May 16th, 2019, 12:54
TRCM's Avatar
Also noted today when I drove it to the shop, that it only does it when the engine/trans are hot (up to normal temps)
Driving it cold today the 3 miles to the shop it didn't do it, but if I torqued the engine against the brake, it would just start.
Took it to the shop as I have a recovering knee injury that was severely aggravated when I replaced my steering with the 1 ton SFR system 2 weekends ago, so I am not risking doing that again by getting in & out from under the jeep. I'll just pay this shop, whom I trust, to do it for me this time.
Old May 16th, 2019, 14:53
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Keep us in the loop. My sister in laws wrangler does the same thing and I haven't been able to pin it down.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old May 17th, 2019, 14:28
TRCM's Avatar
Just picked it up...it was exactly as I suspected...the torque converter bolts were loose and starting to hit the dust cover.
They tightened them up and now no more noise.......
weird noise SINCITY192 OEM Tech Discussion 11 September 26th, 2010 10:37
Weird noise XJ.Atticus OEM Tech Discussion 3 October 24th, 2009 13:09
weird noise anyone think they can help? jpmeiner Arizona Chapter 27 February 26th, 2009 21:55
weird noise GrimmJeeper SoCal Chapter 24 March 5th, 2008 22:45
weird noise. rhino317 Modified Tech Discussion 2 August 25th, 2007 11:34
