Old June 10th, 2021, 08:22
KeeneXJ KeeneXJ is offline
Coolant leak
Tracking down a few coolant leaks in a 2000 sport. A new radiator took care of one; however, Iím also seeing coolant drops collect on the back of the front differential (see pic). Is this consistent with a heater core leak?
Old June 10th, 2021, 09:23
Anak's Avatar
Anak Anak is offline
Stranger
Re: Coolant leak
No picture, but nonetheless, no, that would not be consistent with a heater core leak. A heater core leak would probably show up in the passenger footwell. A coolant smell inside the cabin and a damp carpet are your usual clues with a heater core.
I would start by inspecting the weep hole at the bottom of your water pump. Use a mirror and a light. Look for a coolant trace/path down the water pump casting. It might also follow along the bottom edge of the lower radiator hose.
Old June 10th, 2021, 09:26
boncrshr boncrshr is offline
Re: Coolant leak
No, fortunately. Heater core is usually passenger side floorboards. Check the weep hole on the bottom of your water pump for evidence of leaking (very common and means you need a new water pump ASAP). Also, check around radiator cap and check the overflow hose that goes from filler neck to the coolant tank on inner passenger fender.
Old June 10th, 2021, 11:26
jeep ride's Avatar
jeep ride jeep ride is offline
Re: Coolant leak
Have the cooling system pressure tested.
Coolant leak Philprof OEM Tech Discussion 8 April 8th, 2008 16:54
Coolant Leak kdailey4315 OEM Tech Discussion 9 February 13th, 2008 05:27
Coolant Leak....Help! Chux01Cherokee OEM Tech Discussion 6 May 9th, 2007 11:37
coolant leak kumes12688 OEM Tech Discussion 3 December 9th, 2006 21:40
coolant leak! grasseater OEM Tech Discussion 7 July 3rd, 2004 11:01
