Old June 10th, 2021, 15:06
denverd1 denverd1 is offline
Dana 44 hi steer conversion
looking to replace passenger knuckle with hi steer setup.
https://www.ebay.com/itm/26399621233...0aAujxEALw_wcB
anybody done it? would add some steel to the knuckle to put it double shear with the stock arm. hydro assist
Old June 10th, 2021, 17:22
VAhasnoWAVES VAhasnoWAVES is offline
Re: Dana 44 hi steer conversion
Been done lots.
Doing only the passenger knuckle, I assume you want to run the drag link to the high steer arm and thetie rod on the stock steering horns?
I’d you don’t know off hand, you’ll first want to check if you have Ford or GM knuckles/spindles.
Old June 11th, 2021, 04:46
XJlimitedx99 XJlimitedx99 is offline
If you are planning to run the tie rod on the steering arms, you'll need to ensure the knuckle you're buying has the taper direction the same as your driver's side knuckle. IIRC, the older knuckles put the tie rod on the top and the later knuckles had the tie rod on the bottom. I don't remember the year for the split. 76, maybe?
Check out the Dana 44 bible. Lots of good info in here. https://web.archive.org/web/20060520.../web_rs44.html
When I was researching for 44 options I decided I would buy this kit:
https://www.ebay.com/itm/26433200613...AOSw3dZc5HP k
Haven't ordered anything or built the 44 yet, or might not ever. It seems like a good option though.
'99 XJ - 4.0, AW4, NP231, HP-D30, C8.25, 6" Lift TnT Long Arms on 35s
Build Thread: Project Go Anywhere, Do Anything, Anytime.
Old June 11th, 2021, 12:17
Skruffy's Avatar
Skruffy Skruffy is offline
I had a Teraflex high steer setup on my XJ with TJ rubicon axles. I never did get it to work out like it should. There was always a bit of bump steer.
A while ago I replaced it with Off Road Onlyís Uturn steering system. It is far superior to the Teraflex setup. No more dead spot and no more bump steer.
And you donít need to replace your knuckle. Worth taking a look at.
I think it was around $600 shipped.
Old June 15th, 2021, 21:20
Was hoping that link worked limited. Got anything else?
Old June 15th, 2021, 21:43
Thanks
Old June 16th, 2021, 06:07
the bolt on high steer arms and teraflex knuckle are for two very different dana 44s.
what do you have exactly?
Old June 16th, 2021, 10:08
Skruffy's Avatar
I have a TJ rubicon Ď06 Dana 44. The Teraflex knuckle that I bought was meant for TJs.
The rest of the high steer setup was also meant for a TJ. I know people have done this and had it work out but it was terrible for my Jeep.
Old June 16th, 2021, 10:11
Skruffy's Avatar
I did a thread about this on here.
Search VANCO big brakes and u turn steering and you should be able to find it. At least see what I had in there.
Old June 16th, 2021, 11:17
waggy 44 over here
Old June 16th, 2021, 11:30
Originally Posted by denverd1 View Post
waggy 44 over here
don't think those are even machinable for flat top/hi steer?
Old June 16th, 2021, 12:13
waggy 44 over here
thats what i had assumed.
being that these axles were used for so long and in so many different variations, its honestly not safe to assume anything. rather, look/verify what you have.
first... id identify what knuckles you have. ford knuckles will have 5 spindle bolts, chevy will have 6. (waggy axles used chevy stuff) lug pattern isnt a great indicator, you can make a chevy knuckle 5 lug, and a ford knuckle 6 lug. the caliper bracket and caliper design are also different. another way to tell without removing the hub.
lets assume your waggy axle uses its OE knuckles. youll have GM knuckles/spindles. if you have a flat top knuckle that isnt machined, you can use that knuckle for high steer. dont attempt to machine and use a non flat top knuckle for high steer. if you need a knuckle... an OE one that has been machined works, reid also works. just be sure what knuckle/spindle you are using before ordering.
Old Yesterday, 04:45
They both work for me. Which one are you referring to?
The eBay listing title is "GM/CHEVY/JEEP DANA 44 HIGH STEER ARMS AND KNUCKLES DRIVER AND PASSENGER HD" priced at $400.
Old Yesterday, 18:45
Ebay links work.
44 Bible doesn't work.
Old Yesterday, 18:46
Looks like I have chevy 6 lug. Also six studs on hub
otk conversion compression steer jeeptec Modified Tech Discussion 6 October 23rd, 2011 19:18
Dana 44 Hi Steer Conversion 4LowandGo Modified Tech Discussion 9 February 24th, 2009 11:40
High steer conversion AZ DESERT RAT Modified Tech Discussion 2 March 14th, 2005 07:21
high steer conversion for dana 30 canadian-xj Modified Tech Discussion 2 December 1st, 2004 20:44
D44 Hi steer conversion KarmirXJ Modified Tech Discussion 4 April 29th, 2003 19:01
