Old April 19th, 2010, 01:35
kndrewa's Avatar
kndrewa kndrewa is offline
AW4 filter change pictures
there are tons of threads about changing the filter in your aw4.
however, i couldn't seem to find many with pictures.
here are a few photos for anyone interested.
Old April 19th, 2010, 01:36
kndrewa's Avatar
Re: AW4 filter change pictures
__________________________________________________ _____________
STEP 1.)
drain the fluid
the aw4 transmission pan holds 4 liters of ATF - dextron III.
(the entire transmission holds closer to 9 liters, i only changed the pan volume)
the transmission cross member is right in the way of the drain flow.
i used this small funnel to redirect the flow away from the x-member:
after draining the fluid, i re-installed the drain plug.
not all fluid drains from the pan due to recesses and ribbing.
i will deal with the rest of the fluid in the pan in a few minutes.
kndrewa's Avatar
STEP 2.)
remove the bolts holding the pan to the transmission
they should be torqued to 53-70 in/lbs, but mine came off very easily.
(perhaps tightening these would have stopped my leak!)
removal of most of the bolts is very easy:
some bolts at both ends of the pan require a swivel for easy removal.
the exhaust pipe is in the way at the front of the pan:
the transmission cross member is in the way at the back of the pan:
one bolt was blocked by the exhaust hanger:
i used a ratchet strap to pull the hanger over enough to get clearance:
Old April 19th, 2010, 01:37
kndrewa's Avatar
STEP 3.)
break transmission pan seal
the factory uses red RTV sealant as a gasket.
this sealant gets hot and bakes on as it adheres to the trans and pan.
i used a rubber mallet to tap around the pan to loosen the sealant.
a sharp flat chisel helped to carefully pry the pan loose at a corner:
a quick note about the dipstick tube:
its a 2 piece unit held together with some kind of o-ring.
i couldn't get mine to seperate, so i unbolted the upper half in the engine compartment.
the dipstick tube is wedged in place on route to the engine compartment.
it is now all that holds the pan up - as seen in the lower right:
kndrewa's Avatar
STEP 4.)
drain remaining fluid
as you can see, my transmission fluid was quite dark, but it didn't smell burnt.
transmission fluid is supposed to be a translucent reddish pink.
good thing i will be cycling in some fresh fluid - if yours smells burnt, change it!
quite a bit of fluid stays in the pan after the initial drain:
at this point, i unscrewed the drain plug once again.
tilting the pan allowed me to drain the remaining fluid:
kndrewa's Avatar
STEP 5.)
remove transmission pan from jeep
work the dipstick tube and trans pan out from under the jeep.
it is kind of a game of angles - but you'll eventually weave it out of there.
the tube will remain connected to the pan for the entire procedure:
there are 2 small magnets in the bottom of the transmission pan.
they accumulate the small metallic particles which appear as your transmission breaks in.
i was pleased to see that i had a normal amount of wear as indicated by the metal on the magnets.
the left magnet is cleaned, the right magnet has accumulated metals:
Old April 19th, 2010, 01:38
kndrewa's Avatar
STEP 6.)
prep pan for new gasket
i scraped all of the red RTV sealant from the pan.
i used a bit of parts cleaner and emery cloth on seal surfaces.
(being VERY careful, as parts cleaner should not be in a transmission!)
Old April 19th, 2010, 01:39
kndrewa's Avatar
STEP 7.)
out with the old filter , in with the new filter
the filter is held in place with 4 13mm bolts.
the transmission filter is the dark gray rectangle
with the filter removed:
old filter on bottom, new filter on top:
kndrewa's Avatar
STEP 8.)
re-install transmission pan
its easy from here out!
the cleaned magnets are put back in the pan for re-installation.
note the dipstick tube going to the engine compartment:
feeding the dipstick tube back up to the engine compartment:
the gasket constricted enough at each bolt hole to hold the bolts in place for me.
i put one bolt on each side to get it held in place at first.
one 'prep' bolt on the far left, one near the right side:
torque them down and add fluid - you're done!
Old April 19th, 2010, 01:40
kndrewa's Avatar
APPENDIX A.)
tools used
* shop light
* pocket knife
* ratchet strap
* chisel - wide
* chisel - narrow
* parts cleaner
* emery cloth
* rubber mallet
* shop gloves
* torque wrench
* 3/8 ratchet
* 3/8 extension
* 13 mm sockets
* swivel
* 1/4 ratchet
* 1/4 extension
* small funnel
* long funnel
* flashlight
* punch
Old April 19th, 2010, 01:46
kndrewa's Avatar
i should go ahead and do the 'poor mans flush' now..
..i just ran out of fluid at the time.
i will get more and drain/fill it a few more times.
that should cycle most of the old stuff out.
in the mean time i am happy to report smoother shifts!
Old April 19th, 2010, 03:04
Kittrell's Avatar
Kittrell Kittrell is offline
For the record, fill capacity for the AW4 is 8 liters, or 8.45 qts. And I really hope that was a typo. Torque range on the pan bolts in 53-70 INCH pounds, not ft. 60 ft. lbs will leave you with a nice smooth shaft where thread used to live.................
Nice writeup otherwise. Now just remember to leave the pictures there forever. So three years down the road, when someone comes across this in a search, they don't see a bunch of red Xs!
Old April 19th, 2010, 03:32
xjtrailrider's Avatar
xjtrailrider xjtrailrider is offline
Nice write-up, I would add that getting the pan out is easier if you remove the cross-member. That is also a good opportunity to inspect and/or replace the troublesome transmission mount.
Old April 19th, 2010, 06:07
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
A few things - once you get the pan out, it's easy to get the dipstick tube out using some penetrating lube, a tiny bit of heat, and some twisting. Then it's easy to put both back in separately.
Also, a brass wire wheel is great for cleaning the edge of the pan - softer than the steel so it won't hurt it and you can just go to town. I used brake cleaner instead of parts cleaner, it does a decent job of softening RTV and evaporates very quickly so no worries about leaving it in the pan.
Other than that, excellent writeup!
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old April 19th, 2010, 08:57
kndrewa's Avatar
thanks! yes, a typo, and one that i can't fix now.
maybe a mod can go in and edit that post for me.
Change Trans filter cardboard OEM Tech Discussion 5 February 17th, 2010 07:53
fuel filter change 93xjowner OEM Tech Discussion 5 October 4th, 2009 16:24
filter change with TNT Y-Link Justpunchit Modified Tech Discussion 5 September 9th, 2008 17:46
Oil filter location change? asatxj OEM Tech Discussion 20 March 9th, 2005 13:12
aw4 fluid and filter change Poison OEM Tech Discussion 2 July 6th, 2003 11:11
