Old October 18th, 2020, 14:31
NOTNSUV's Avatar
NOTNSUV NOTNSUV is offline
You Guys ROCK!
Rear Suspension Issues
New stops, one where there was none. Felt good on the street, now to flex, see about bolt interference, and get it on the trail with my usual load.
Thanks for the guidance folks, at least I'm on track now. I think the OME springs are soft for comfort, and it does ride smooth, but I might want a more HD ride. One thing at a time.
Sent from my E6810 using Tapatalk
I'm a 'Do-it-Twice' kinda guy.. or..
Cross thread's better than 2 lock-washers
1999 XJ Sport 4.0L Black
Old October 18th, 2020, 14:34
NOTNSUV's Avatar
You Guys ROCK!
One more. Stance appearance is due to front fenders cutout more than rear I'd say.
Old October 18th, 2020, 21:43
Evan03 Evan03 is offline
People think mines lifted like 6" due to front fender height.
In the rear im not running bump stops at all.
I am bumped in the front to keep my track bar out of tge oil pan.
Glad your on track.
Old October 25th, 2020, 01:05
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
Re: Rear Suspension Issues
What happened to the pic in the other thread and notice of the shackle mount being damaged? No concern?
Evan03, how would a flat (worn) spring cause a smoother ride??? That seems peculiar to me... is the argument is that its softer since its worn?
I'd think that it has lost its "spring" since they don't return to normal U shape. It'd have to be able to reverse arch to even dampen anything? I'd argue its a much worse ride and akin to driving with a board as a spring. His setup worse off than yours, since you have shackles and srbs and mainly because you have bad ass Fox shocks doing the grunt work
I vote both of you change them worn out springs! XD
97 XJ lift lockers 35s mid arms 9"/hp30 trussed warn hubs wj brakes 1ton OTK 4.56s etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old October 25th, 2020, 07:15
maxbraketorque maxbraketorque is offline
There's no difference in stiffness of a new or fatigued metal spring unless the fatigued spring is close to fatigue failure, or if its developed a crack (and therefore is again close to failure). The yield load where the spring takes a new set could go up or down though. Most likely reason for a softer ride with the fatigued spring is that the shackle angle will be greater for the flat spring, and this reduces the effective spring rate.
Old October 25th, 2020, 08:32
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
The "smoother ride" is not related to metal fatigue which is small cracks that occur just before catastrophic failure and separation of the metal, it is due to geometry. A saggy ( not fatigued ) leaf spring is longer than a similar not sagged leaf spring and the shackle angle is less upright. The closer the shackle is to a vertical angle, the higher the effective leaf spring rate. When the shackle is laid back at an angle, it actually becomes a moving link with the spring, and the spring ride will feel softer.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old October 25th, 2020, 17:03
NOTNSUV's Avatar
You Guys ROCK!
I've spent 3 days on a recovery of a Tacoma high in the Ruby Mtns of Nevada. Just checking back in.
I'm not clear on the damaged shackle mount. I haven't removed any pics and don't even know which one was referenced. Also have noticed nothing indicating a damaged mount. Maybe more pictures are in order (but hopefully not of the HUGE variety in this thread.
Met a great bunch of folks during today's recovery. Gang out of Elko that are available day or night, without charge, just notify with details on their FB page and they come out in droves with killer 4x4s.
I might pick their brains and ask them to look over my setup in person for diagnosis and resolution. Not giving up here tho'.
Getting dang cold here suddenly so it's shop heater season.. yuk. 6* tonight with -20 wind chill. Got that Toyota out just in time (it was at close to 10k elevation).
Old October 25th, 2020, 17:10
So a saggy, or dead flat in this case, isn't "softer" than that of a properly set up rear suspension- with U shaped Leaf packs and 45* shackles is what we are agreeing on ya?
Old October 25th, 2020, 17:17
NOTNSUV's Avatar
You Guys ROCK!
Old October 25th, 2020, 17:24
In this photo, the shackle box appears folded:
Old October 25th, 2020, 17:31
NOTNSUV's Avatar
You Guys ROCK!
Hmm.. I'll look again but need a 'good' one to compare. Maybe another pic from the side will help?
Thanks.
Old October 25th, 2020, 18:59
Thanks.
A side pic might help. The shackle box outboard wall flares open towards the back of the box, but its parallel to the unibody rail starting from the bolt hole and going to the front of the box. Yours looks pretty taco'ed, but it could be he photo angle and fish-eye exposure.
Old October 25th, 2020, 19:12
I see it making a Z shape... so that'd be a hellova fish eye!
Old October 27th, 2020, 10:52
NOTNSUV's Avatar
You Guys ROCK!
Ok, shackle box is fine. But I'm finding marks on frame, body each side. Longer or boomerang shackle the fix?
Old October 27th, 2020, 12:09
TRCM's Avatar
TRCM TRCM is offline
it's a combination of the shape of the box and the weird angle the pic was taken....
Rear Suspension issues XJwheelman Modified Tech Discussion 7 September 27th, 2013 04:36
suspension issues JoeyBottles Modified Tech Discussion 5 July 25th, 2012 17:46
Front Suspension Issues mavrick Modified Tech Discussion 12 December 23rd, 2010 22:09
Front suspension Issues .... hemiriffic Modified Tech Discussion 4 March 15th, 2010 14:48
Suspension Issues... Grant H. Modified Tech Discussion 8 April 4th, 2007 18:38
